m house
Everything posted by m house
  1. oh my bad,even still gaz i would rather go with a excedy they kane take a fuckn raping, they make sum good clutchs, i would stand by them, my 2 sense worth any way, millz
  2. gaza, cheap dose not = good if i was you i would stick with wot i no, my m8 has a f1 clutch set up in hiz kar and it cost him a pretty penny, if they were that good u would have herd about them and ppl would have them, myself i wouldnt buy a heap of shit f1 rip off clutch thats gana shit its self afta a hard day of raceing/burnouts millz
  3. keen as a bean let us no wots going on when and were chers millz
  4. illd run with the 12a decomp rotas then u kan bolt a turbo on the side if u hav the need dosent mean any thnk if you roll a 12a decomp engine i do , if its that bad i make better power than sum 12as with i ida,, cheers millz
  5. m house
    Escort Diff
    grants automotive in whakatane 12a monster brige rebult fully workd 4banga massive jets all the bells and whistles poretd exhaust maifold wound the fuel presure mack daddy tune by guys who no wot they r doing that holds the fastest na rota in nz.but yea lsd is getin shorten and put in when i get time keeps cunts honest cheers milz
  6. m house
    Escort Diff
    i dont no wot sort of diff i got in my esky but its takeing a fuck hiding 161.8kw atw and when it blows locker is the only way
  7. thats the best way drill the driveshaft holes out and the diff head holes out 13mm hole in both use 12mm h/t bolts with nylock nuts with locktight easy az ive done it swt ha drive shaft hasnt kum out of my esky and i do 8-9000 rpm swing os haha swet miilz
  8. any one need any thing done, any welding s/s,aluminuium,m/steel, cast drawings/diagrams would b a plus cheap as chips 15 buck a hour plus materials thats if i dont have it cost me nothing,swt swt millz
  9. very easy to weld to cast do a bit of it u use high ten 8 arc rods and pre heat the steel and pen it. shouldent crack if u call yourself a welder. any 1 wont any CAST welding done ill do it 4 nothing tur. millz
  10. hay bro if u get stuck courier over to me il do it for nothing dont do any thing at work any way do u know wer to cut the sump swet,millz
  11. hay bro if u get stuck courier over to me il do it for nothing dont do any thing at work any way do u know wer to cut the sump swet,millz
