V8Pete Posted June 20, 2007 Share Posted June 20, 2007 Mikuni Out of curiosity, which flywheel are you using? Is there much/any difference between C20NE and [whatever the other one is] flywheels? Definitely feels that way driving them, but may just be DOHC cf. SOHC? Quote Link to comment Share on other sites More sharing options...
mikuni Posted June 20, 2007 Share Posted June 20, 2007 I was told that the twincam (X20XEV) ones are huge, but it turns out they are essentially the same as the C20NE ones. It looked to be in better condition and didn't have holes drilled out of it from factory ballancing like the C20NE one did, so we opted to use the twincam one as it has probably been cast from a better material. Quote Link to comment Share on other sites More sharing options...
V8Pete Posted June 20, 2007 Share Posted June 20, 2007 Oh, thought you ended up with Ecotec (C20SEL?). The C20NE is so much freer revving and responsive than the C22SELs I've driven. Wonder why that it is then. Quote Link to comment Share on other sites More sharing options...
WDE_BDY Posted June 21, 2007 Share Posted June 21, 2007 DELETED Quote Link to comment Share on other sites More sharing options...
mikuni Posted June 21, 2007 Share Posted June 21, 2007 Yeah man, the ecotec I have is X20XEV. The first letter "X" or "C" is the 'generation' of the engine, but use much the same block so you can pretty much link them together, just X can after C. The C22SEL looks identical and comes in the Vectra B also, but is a completely different engine. The next X is the compression of the engine, X meaning greater than 10:1 I think it is, though N and S mean different things also. This may be where the sluggishness comes from in the 2.2L? The V at the end just means it was the Volume engine - the most common released in that model. Thats how I understand it to be anyway. Quote Link to comment Share on other sites More sharing options...
Spencer Posted June 21, 2007 Share Posted June 21, 2007 thats not how the actual atlantic ones run though aye? the one i seen has a tiny ring gear so the motor can sit lower. obviously cant use that without the atlantic transaxle Quote Link to comment Share on other sites More sharing options...
Rusted Posted July 7, 2007 Share Posted July 7, 2007 Quick question. Is a 10lb flywheel to light for a 200hp engine? (Factory meat been cut in half + some) Quote Link to comment Share on other sites More sharing options...
mikuni Posted July 8, 2007 Share Posted July 8, 2007 Quick question. Is a 10lb flywheel to light for a 200hp engine? (Factory meat been cut in half + some) I'm aiming for 200hp eventually and my flywheel was 22lb now 12lb. I think you could go to 10lb in a light car, I haven't noticed any detrimental effects of using the light flywheel. Oh and for the purposes of this thread, it hasn't exploded yet Quote Link to comment Share on other sites More sharing options...
