Hemi Posted February 4, 2008 Share Posted February 4, 2008 well today i wired up the temp gauge so it works (yay!) and also managed to wire up tacho after trying 3 diff ways of doing it i just took main earth for all coils , extended it to cabin and into tacho , so coils now ground out through tacho haha . works so im happy its still got a bloody miss which is pissing me off but there are more important things to fix at the mo ..its getting so close to being back on road Quote Link to comment Share on other sites More sharing options...
Hemi Posted February 18, 2008 Share Posted February 18, 2008 GUESSS WHAT!!! it on the road , wofd regod and running properly FUCKING YES!!!!! already done 1200k's in it 1 Quote Link to comment Share on other sites More sharing options...
Hemi Posted February 27, 2008 Share Posted February 27, 2008 so after the nats and much thrashing , also slammer telling me it was blowing black smoke everywhere i gave it a look over and tuneup type thing ...first thing plugs and black ..and furry .. furry ..jesus must be running rich . nxt idle wont work properly .. so i pulled all the vacuum idle bullshit off i can be fucked dealing with it anymore etc . then i pulled off intake and cleaned airfilter ..found dust all through intake so that means the filter sucks ..ok cant change at this time so i just sprayed crc over the element . i then looks at the airflow meter .. one of the wire was covered in shit .. well that wont help anything will it .. so i cleaned that and replaced i also cleaned throttlebody while i was at it *twas filthy and sticking at idle position) . after all this i adjusted reisitor on airflow meter a tad and took for a blat .. plugs are already changing colour YUS! . on all the rattle i managed to get through thrashing the car .. number one exhuast .. well lucky i looked cos its was about to fall off at the headers rofl . and yuh thats what i did today 1 Quote Link to comment Share on other sites More sharing options...
Hemi Posted May 31, 2008 Share Posted May 31, 2008 soo havent had a write up in ages so thought id give the thread a bit of an update . first off . replced old speakers with new items. kept them hidden under the old covers though second today i got sick of the vibration i have that im positive is coming from the gerbox area out comes engine ( its FAR easier to take whole lot out due to clearnace issues at the firewall-gbox-engine junction) next off took one look at the engine loom and went fuck , needs to be tidied up all taped up , sexy empty engine bay (note the airhorns bitches) and split the g-box and engine to check for anything suspicious (loose clutch springs etc) to no avail found nothing , small posibility of sandwhich plate ratlling but i highly doubt that i did however find a small bolt that had fallen down i between a bracket on the engine , this could be a possible cause for mass rattling so gonna do more 2moz like tidy up engine bay loom/s steam clean it cos there oil from when breather fell of every fuckung where and im gonna give my best shot at hooking heating up (if you saw the clearances you'd understand why it not done yet) chur chur 1 Quote Link to comment Share on other sites More sharing options...
Hemi Posted June 2, 2008 Share Posted June 2, 2008 soo today i tidied up the loom in the engine bay a bit more and fixed some shit that was broken , removed the petrol vapour canistor thing and steam cleaned bay . i also hooked up the heater pipes , took like 2 hours to get everything right , fuck there is NO room under there to do anything . but stoked they are hooked up now ruined exhuast manifold gaskets so have them + flange gaskets on order now was gonna start it back up today but i was too tired and pissed off to do so Quote Link to comment Share on other sites More sharing options...
Hemi Posted June 2, 2008 Share Posted June 2, 2008 project discussion viewtopic.php?f=18&t=9633&start=400 Quote Link to comment Share on other sites More sharing options...
Hemi Posted June 4, 2008 Share Posted June 4, 2008 k so its all back together now have replced a few gaskets , blocked a few waterlines and just tidied stuff up . i also hooked up the heater and guess what...IT FUCKING WORKS!!!! i slao have these pics 1 Quote Link to comment Share on other sites More sharing options...
Hemi Posted June 9, 2008 Share Posted June 9, 2008 another update *no pics sorry* was flushing cooling system on friday and while it was doing its thing i cleaned interior . started vacuuming passengers footwell when lo and behold ... drip...drip....drip.... ...fuck so i took a look and sure enough it was coming out of the heating box ... which is crap beacuse you can pull the fan box and evapourator box out piss easy , but the heater box is right behind everything. so i took whole dash apart which took 1.5 hours .. the whole dash there was a bare firewall staring at me when i was done. Anyhow got heater box out and pulled the core out.. crack at one of the ends where it joins onto plastic end tanks. so disassembled part of the core cleaned up area and silver soldered the crack back up .. neato i then slammed it all back together checked for leaks and thank god there were none finished flushing cooling system .. which btw is now running on tec coolant *propolyene glycol* also fixed airleak for airhorns Quote Link to comment Share on other sites More sharing options...
Hemi Posted June 16, 2008 Share Posted June 16, 2008 no update just pics 1 Quote Link to comment Share on other sites More sharing options...
Hemi Posted December 24, 2008 Share Posted December 24, 2008 k well its been sitting out back gathering rust so a week ago i decided to do somthing about that due to it being summer and such . soo i got new steering rack boot , new set o cheap arse tyres ling longs and a set of kingies for it .. now that was a fucking mission but managed to get put onto and onto it guy called clint from kapiti bnt , what a fucking legend he was kdfl-32 for the fronts and kdrl-11 for the rears only raised the front up about 15mm and the ride is a hell of alot more pleasent then the cutties xmas do came up so i decided to do a skid ... and got a diff clunk going on , well heres what happned (ive never seen it happen before) the spider rod thig elongated the holes and then one dropped out completly .. woah oops so being the mechanic i am i decided to throw a mig in there and get everything back together till i get another diff i expect t to last all of 3 minutes before it chenobyls itself but if it gets me to the old man today for xmas ill be stoked 1 Quote Link to comment Share on other sites More sharing options...
Hemi Posted January 13, 2009 Share Posted January 13, 2009 update time , went for warrent check and failed on a seatbelt , tierods , uncaptive springs and locked differential made springs carptive by mean of washers. new seat belt new tierods then set out to find another r160 diff .. to no avail anyhow , gave jason at niscars a ring and he reckon he had one out back somewhere , so i went down and had a look . wasnt a r160 but i kept my mouth shut and grabbed it. got it back to the workshop and it was a r180 viscous lsd out of a attessa bluebird fucking stoked! splines fitted in no problems and set about taking buttons out of the r160 spidergears to put into the r180 when i realised that bacuse it was an lsd eveything is alot tighter not allowing the buttons to fit in (the buttons hold the halfshafts in by means to a bolt and later models have a clip holding it in) so i ended up rangi'ing somthing up to keep them in till i can get my splines grooved for the circlip . bolted striaght into the bluebird easily . nonly prob i ran into was pinion flange being different , so changed that and viola the 910 now had a lsd r180 diff ... saw all the room there and i might give a r200 a go when i find a longnose sucker :) stoked as . also found out that those types of diff have the ratio stamped on the crownwheel for easy refrence , hows that for convieniant 1 Quote Link to comment Share on other sites More sharing options...
Hemi Posted February 2, 2009 Share Posted February 2, 2009 well ths now has current wof and rego now , pretty stoked about it all just about wasted the guy that did the warrent on it. but then took it somwhere else. picked up cv hlafshafts from u12 bluebird and they are now sitting waiting to have somthing done with them (no pics sorry) did some shit with the loom , mainly finding all the wire and shit that wernt doing what they were ment to , fuck loom is soo dodgy all these ensor wire crossing and shit dodgy as . but car is now legal yay!!! so can drive round etc now Quote Link to comment Share on other sites More sharing options...
Hemi Posted February 6, 2009 Share Posted February 6, 2009 the 910 halfshafts vs the r180 vlsd left hand shaft ( i get the feeling im gonna have to convert the rear to cv ugh ) some pics 1 Quote Link to comment Share on other sites More sharing options...
Hemi Posted July 11, 2009 Share Posted July 11, 2009 long time no update, have replaceed the front swaybar bushes with nolathane items as the old ones were rooted then while carring out a prewof inspection i found the rear wheel bearings to be fucked , so changed them for new items . also noticed that the exhaust was leaking and seeings as the majority of the length was now 2 1/4" i decided to biff the old section that went through the subframe and halfshafts etc , and make a new one . and whilst at chase getting the required section of pipe (combo sections rules my face) . i decided to flange the exhaust so i can easily remove parts of it . i prefer to gas weld exhaust sections mainly because i reckon it looks way tidier the whole exhaust bolted together new section vs old section: mount plates that i cleaned and painted after welding all the flanges i threw it back onto car and started bolting up .. hrmmm somthings not right here F$%K PIECE OF F&*KING S*&T flanges must have moved at some point , oh well at least its easy to unbolt and redo my header bottle this is an r180vlsd so gotta fix the clearance issues of the zorst then im going to rebush the whole car (after new tyres for front) . then some 15" rims with lower profile tyres because the ride is quite firm apart from the sidewall sway also comment etc most welcome , starting to lose interest and shit (fuckign winter) discussion thread 1 Quote Link to comment Share on other sites More sharing options...
Hemi Posted July 16, 2009 Share Posted July 16, 2009 well took cam cover off today due to sneaking suspision , turns out ive been running the bluebird with a tooth out for ohhh a year and a half haha .... and photobucket is down for me F^&%(# 1 Quote Link to comment Share on other sites More sharing options...
Hemi Posted September 25, 2009 Share Posted September 25, 2009 so here is what i put in the 910 today adn for lols while the rear subframe was unbolted from the diff thankyou and goodnight oh i had to modifiy the rear mount rearwards 1 inch , bigger hole for studs and also them being further apart .. i am well stoked , currently looking itno clutchpack units and then a cv conversion then the ill be happy with the final drive . 1 Quote Link to comment Share on other sites More sharing options...
Hemi Posted October 15, 2009 Share Posted October 15, 2009 its not finished yet , just needed a comparison to make sure the 3 hours of sanding and polishing was worth it Quote Link to comment Share on other sites More sharing options...
Hemi Posted October 16, 2009 Share Posted October 16, 2009 useless post , decided to get the center done today , another 3 hours of sanding ....fuck im not looking forward to the other 3 and i still need to tidy up the lip!!!! Quote Link to comment Share on other sites More sharing options...
Hemi Posted November 22, 2009 Share Posted November 22, 2009 more rim pics , need tp post htem up so i feell better about spending untold amounts fo time getting them shiny , i really dislike sanding shit now . one more left to do now but needs to be repaired first , then its up to pickapart to get some different sized tyres to check for fitment looking at 185/55's but not keen to psend excessive amounts of $$ on such things till i know they will fit nicely 1 Quote Link to comment Share on other sites More sharing options...
Hemi Posted December 4, 2009 Share Posted December 4, 2009 take that ca18det fiends!!!! ... yes that is a 4port ca oh hello oil cooler dont get too excited ... i got home and realised that the lower manifold was missing ...offered the guy $50 to find it because i really need it as the 8 port wont fit . plans ... well tbh i dont want to use this motor for my plans because im aiming for response not massive hp . however plans for the motor im building are: ca18det . ca18de pistons exahust cam on inlet side (so some adjustable cams gears) a gt2860rs (disco potato) with .64 a/r turbine housing . standard ecu remapped bosch 044 external fuel pump (prob wont need it but yea) some form of upgraded in tank pump . gtr injectors . z32 afm sr20de throttle body thats it for now im aiming for pickup to start at 2.5 -3 g and carry on to redline aiming for a lowly 240hp atfw . and getting that should take about 12-14 psi , which is easy . i am also going to go for a 8 port head and manifold to keep the low torque , mainly because i want it to be a 'fun' car so looking for responce as opposed to outright power . but as we all know shit changes etc. thanks you for looking 1 Quote Link to comment Share on other sites More sharing options...
