jaymz Posted January 8, 2007 Share Posted January 8, 2007 I'm just cleaning out my engine bay. I don't want any un neccasary things in the engine bay. ie. battery. I have got a spot weld drill bit and have been drilling for quite a while and can't see much progress. Do I just keep percevering or is there some knack to it. I'm fixing the car up to show standard so i dont wanna just hack it off with a grinder. Quote Link to comment Share on other sites More sharing options...
Gaz Posted January 8, 2007 Share Posted January 8, 2007 grinding it off is possiable to make it clean ass. Id say cleaner. Quote Link to comment Share on other sites More sharing options...
Hemi Posted January 8, 2007 Share Posted January 8, 2007 true story^ or use diegrinder either or , work alot faster and usually look better Quote Link to comment Share on other sites More sharing options...
Guest kornstar Posted January 8, 2007 Share Posted January 8, 2007 yeah die grinder FTW. Quote Link to comment Share on other sites More sharing options...
Guest 2ltescort Posted January 8, 2007 Share Posted January 8, 2007 i got a spot weld drill and it works real well it has a little bit in the middle so you can addjust deapth and a small cutter head that change cost about 60 bucks but worth every bit when you use it Quote Link to comment Share on other sites More sharing options...
Bullitt Posted January 8, 2007 Share Posted January 8, 2007 Bah just use a regular drill bit and weld the resulting hole up. Always worked fine for me Quote Link to comment Share on other sites More sharing options...
tortron Posted January 8, 2007 Share Posted January 8, 2007 hammer and chissel boe Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 9, 2007 Share Posted January 9, 2007 I've never had problem with a spot weld drill, unstiched a hole drip rail off a ke70 sedan once with one and pick a part, so its not to hard. But you probably need a chisel aswell to break off the little remaining bits of weld around the hole Nice Allan Quote Link to comment Share on other sites More sharing options...
Guest 2ltescort Posted January 9, 2007 Share Posted January 9, 2007 the spot weld drill i have doesnt drill the weld it drills around the spot then you remove the panel and grind what is left off works very well the panel are undamaged like you get with a chisel and hammer or like a whole that you get when you drill the center this thing works real good Quote Link to comment Share on other sites More sharing options...
