jaymz Posted January 7, 2007 Share Posted January 7, 2007 how many of you have takin the underseal off your cars? whats the best way? I've heard there's no easy way, but surely there are better ways to do it then others Quote Link to comment Share on other sites More sharing options...
Guest kornstar Posted January 7, 2007 Share Posted January 7, 2007 is that the black tar shit? sticky as fuck? i had a ton of that in my kingys boot, best to scrape it off if u can, then wire brush in drill the rest to finish Quote Link to comment Share on other sites More sharing options...
Gaz Posted January 7, 2007 Share Posted January 7, 2007 There is a topic somewhere about it. Somebody on here tried a few methods. Search it Quote Link to comment Share on other sites More sharing options...
thminiman Posted January 7, 2007 Share Posted January 7, 2007 dont know what stuff your talking about, if its the stuff on the outside of the car, underneath etc, then try scraping as much off with a chisel /paint scraper, then attack the rest with petrol and fuckloads of rags. if you talking about the sound deadening shit on the inside of the car. then aparently dry ice on it for about 20mins, then smack it a few times with a copper hammer (as to not dent the metal) then attack it with a chisel. Quote Link to comment Share on other sites More sharing options...
avenger79 Posted January 7, 2007 Share Posted January 7, 2007 why people remove this stuff is beyond me. hammer&chisel, set a good day aside for removing the stuff. Quote Link to comment Share on other sites More sharing options...
mk5corty Posted January 7, 2007 Share Posted January 7, 2007 i removed alot of it to get to the rust, it didnt seem to have served its purpose very well. Anyways didnt try dry ice but did use a heat gun and a scraper worked pretty decent. Quote Link to comment Share on other sites More sharing options...
WDE_BDY Posted January 7, 2007 Share Posted January 7, 2007 DELETED Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted January 7, 2007 Share Posted January 7, 2007 15 hours with stripping disks in the drill I got from mitre 10 like this http://64.78.59.162/merchant.mvc?Screen ... ode=SIDBLK Quote Link to comment Share on other sites More sharing options...
mark105 Posted January 7, 2007 Share Posted January 7, 2007 once you strip it all off what do you put in its place? Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted January 7, 2007 Share Posted January 7, 2007 once you strip it all off what do you put in its place? I used POR15 Metal Ready http://www.por15.co.nz/POR15Prod/metalready.htm Followed by POR15 http://www.por15.co.nz/POR15Prod/rustprevpaint.htm Then coated it with underseal..... I didn't want to do it again Quote Link to comment Share on other sites More sharing options...
J2Racing Posted January 8, 2007 Share Posted January 8, 2007 once you strip it all off what do you put in its place? I used POR15 Metal Ready http://www.por15.co.nz/POR15Prod/metalready.htm Followed by POR15 http://www.por15.co.nz/POR15Prod/rustprevpaint.htm Then coated it with underseal..... I didn't want to do it again how did you get the underseal back on, Some dumb arse has taken it off the floor of my capri. Been told it never had it. But as the car was sold new in CHCH it was done before it went to the yard. I know you can spray it on but how the hell do you get it high enough to work under it. Using axle stands I'd still need 6 midgets on roller skates. Quote Link to comment Share on other sites More sharing options...
tortron Posted January 8, 2007 Share Posted January 8, 2007 por15 = teh win, probably the best substance known to man, close second is probably linseed oil = does everything *known to man refers to used on cars no doubt Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted January 8, 2007 Share Posted January 8, 2007 how did you get the underseal back on, Some dumb arse has taken it off the floor of my capri. Been told it never had it. But as the car was sold new in CHCH it was done before it went to the yard. I know you can spray it on but how the hell do you get it high enough to work under it. Using axle stands I'd still need 6 midgets on roller skates. The trick is to use the brush on under seal Quote Link to comment Share on other sites More sharing options...
tortron Posted January 8, 2007 Share Posted January 8, 2007 or put the car on its side. rotissory would be mint. have only seen them for vw's tho but are no doubt made for other cars also iv seen like 'roll bars' that you attatch to your wheel nuts then you can roll the car onto its side without any damage and its easy to do Quote Link to comment Share on other sites More sharing options...
J2Racing Posted January 8, 2007 Share Posted January 8, 2007 how high did you have your car when you brushed it on. Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted January 8, 2007 Share Posted January 8, 2007 or put the car on its side. rotissory would be mint. have only seen them for vw's tho but are no doubt made for other cars I'd have killed for a rotissory... I was covered head to toe in sticky half melted underseal by the end of the day. also iv seen like 'roll bars' that you attatch to your wheel nuts then you can roll the car onto its side without any damage and its easy to do The bogan way of doing that is to roll it on to a couple of matresses Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted January 8, 2007 Share Posted January 8, 2007 how high did you have your car when you brushed it on. Just on axle stands. Not idea by any stretch but it was my only option Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted January 8, 2007 Share Posted January 8, 2007 por15 = teh win, probably the best substance known to man, close second is probably linseed oil = does everything*known to man refers to used on cars no doubt POR15 rocks! ....I'm toying with redoing the out side of the car with the UV tolerant POR15.... with a roller, a true Getto pait job Quote Link to comment Share on other sites More sharing options...
WDE_BDY Posted January 8, 2007 Share Posted January 8, 2007 DELETED Quote Link to comment Share on other sites More sharing options...
avenger79 Posted January 8, 2007 Share Posted January 8, 2007 Those wire wheels^ are good,last forever. Quote Link to comment Share on other sites More sharing options...
