Gaz Posted October 4, 2006 Share Posted October 4, 2006 Mint sleeper if it can get traction! My engine I am putting in is 130kw rated and im sure thatll be too much power to handle. Since im too much of a lazy cuint with bugger all moolah at the mo I havnt even really started to put it in. Just buying all the peices I need up. I know 298RWkw in a lightened escort with well engineering rear end will bag a 9.0s 1/4. Thats fast. I want 200RWKW with about standard weight. Should pop a very low 12 easy peezy with some decent tyres. Quote Link to comment Share on other sites More sharing options...
Eskorted Posted October 4, 2006 Author Share Posted October 4, 2006 far out 9s in a scort would be crazy im keen on doin 12s tho give alot of people stick! u got that CA/SR dont ya? wouldnt mind goin sr. easy cheap power i spose Quote Link to comment Share on other sites More sharing options...
Gaz Posted October 4, 2006 Share Posted October 4, 2006 Yeah 12s is fast enoguh for a street car. Most strret evos etc that people do up seriously would be around that fast. I got the Ca. After all my research etc I found the Ca is actually a better engine. Also it seems better suited to the small escort. You should search for the malta escorts. They run 9 sec passes with 298kw sohc pinto turbocharged mk1s. One of the Na ones does a 12 even. They go hard out on there 2l pintos there. Quote Link to comment Share on other sites More sharing options...
Eskorted Posted October 4, 2006 Author Share Posted October 4, 2006 mint thanks ill have a search! good luck with the ca bro! let us kno how it goes Quote Link to comment Share on other sites More sharing options...
peteretep Posted October 5, 2006 Share Posted October 5, 2006 the 2wd cossie had 204bhp and the rs500 and 4x4 sapphire had 224bhp Quote Link to comment Share on other sites More sharing options...
escortman Posted October 5, 2006 Share Posted October 5, 2006 1600 heads always crack dont they? Not that I have heard of. Not too sure however. yeh it is a very common thing to happen to the 1600 but between 2 and 3 chambers, they still run fine tho, thats wat my mechanic sed, and hes the shiz for oldskool questions especially fords when hes not drunk aye corrupt Quote Link to comment Share on other sites More sharing options...
peteretep Posted October 5, 2006 Share Posted October 5, 2006 have you guys seen the august classic ford - they made a 2.4L pinto, had 208.3bhp @ 7020rpm and 186.2 lbf.ft @ 5324rpm. The crank was so huge they had to take out some metal on the sides to give the rods room, it had 11mm extra over a normal crank Quote Link to comment Share on other sites More sharing options...
Eskorted Posted October 5, 2006 Author Share Posted October 5, 2006 ha thats pretty intense for a pinto. should look that up to Quote Link to comment Share on other sites More sharing options...
Gaz Posted October 5, 2006 Share Posted October 5, 2006 I know the Kent 1600 head is bad for cracks accross where you said. Thats one huge stroke for the 2.4l. Bet it would rev too well. haha Quote Link to comment Share on other sites More sharing options...
peteretep Posted October 5, 2006 Share Posted October 5, 2006 they said they could have gotten a bigger crank too, 90mm Quote Link to comment Share on other sites More sharing options...
OSC Posted October 9, 2006 Share Posted October 9, 2006 200hp is VERY doable from a pinto ive seen 330hp 2.3l pintos and the max most ppl get is about 240hp tho but my advice would be grenada/siera saphire intake manifold aftermarket bolt on turbo manifold turbo off a vg30det a link computer use a vl comodoire fuel pump and a vr4 intercooler on a standard pinto maybe a mild cam and you would have a torquey very driveable streeter Quote Link to comment Share on other sites More sharing options...
Gaz Posted October 9, 2006 Share Posted October 9, 2006 ^^^^ Use some grammer..... we are taught it all through our lives for a good reason....!!! Guy I just brought my hilux axles off had a 192hp @ the wheels 2l pinto. Thats major power. Saw the dyno sheet and all cause I was a bit sceptical. Was running twin 45s, a $2000 head from a place in Chrchr. custom ground cam. Power was from 6500 to 8500, Forged internals and blueprinted all round. Electronic ignition, HUGE front bowl sump. ummm cant member what else. Now thats one pretty modified 2l if you ask me. Quote Link to comment Share on other sites More sharing options...
