Guest 82EVO Posted January 11, 2006 Share Posted January 11, 2006 ive managed 2 score a cheap turbo sohc 4g63 for th lancer, its in good cond (3 0wner) but iis still 20 years old so i wana recondition it but i want to upgrade the turbo. does anyone know any good ones that will bold up? cheers Quote Link to comment Share on other sites More sharing options...
coltspeed Posted January 11, 2006 Share Posted January 11, 2006 on the std manifold the tc05,tc06,td05 and td06 all bolt straight on. i didn't include the td04 cause i don't know if it's a straight swap and besides all the other turbos i mentioned are bigger and better anyway Quote Link to comment Share on other sites More sharing options...
TygerTung Posted January 11, 2006 Share Posted January 11, 2006 The TD04 bolt straight on, but it's smaller than what you've got now. Quote Link to comment Share on other sites More sharing options...
rxtoy Posted January 11, 2006 Share Posted January 11, 2006 has anybody put a TD turbo on a TC manifold??? i always thought that they had a different exhaust manifold pattern??? i know the outlet to the exhaust is different (unless you've got a late model 12 valve engine), 3 bolt unstead of 4 but this wouldn't be a major to get around. would definitly be interested to find out for sure, i've been planning a bit of a TC05/TC06/TD05 combo (housings from the TC's and internals from the TD are meant to make a pretty good combination) but TD05 would be a hell of a lot easier. cheers Matt Quote Link to comment Share on other sites More sharing options...
isnowi Posted January 11, 2006 Share Posted January 11, 2006 I know for a fact that tc05 will bolt straight up to a vr4 td05 manifold, the tc05 i have is an 070 housing, and the holes line up perfectly, ie the manifold and turbo housing are the exact same bore, however if you are going to a larger housing ( to flow more gas ) tdo5 big 16g is an 080 housing AFAIK, then you would need to do some porting to smooth the gas flow. so going on these observations there is no reason that it shouldn't work in reverse. Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted January 11, 2006 Share Posted January 11, 2006 my mate had a td05 off a vr4 on his sirus dash fwd (galant i think) bolted straight on Quote Link to comment Share on other sites More sharing options...
rxtoy Posted January 11, 2006 Share Posted January 11, 2006 sweet, thats good to know, will definitly make it easier to upgrade. cheers Matt Quote Link to comment Share on other sites More sharing options...
coltspeed Posted January 12, 2006 Share Posted January 12, 2006 i'm running the tc06 on mine at the moment but will likely hybrid it td05 once i have my intercooling sorted out Quote Link to comment Share on other sites More sharing options...
Ogre Posted February 1, 2006 Share Posted February 1, 2006 Theres a FWD sigma down here at a wreakers with a td06 fitted....dousnt look like there been any mods done to fit it Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted February 1, 2006 Share Posted February 1, 2006 Theres a FWD sigma down here at a wreakers with a td06 fitted....dousnt look like there been any mods done to fit it wouldnt that be a tC06 not a tD06 ? Quote Link to comment Share on other sites More sharing options...
Guest 82EVO Posted February 1, 2006 Share Posted February 1, 2006 yea mines a tc06 Quote Link to comment Share on other sites More sharing options...
macabre Posted February 2, 2006 Share Posted February 2, 2006 you can buy my td05 if you want, mint as condition. Im gonna runn something bigger in my EX Quote Link to comment Share on other sites More sharing options...
