HUNTD Posted August 27, 2005 Share Posted August 27, 2005 I am getting sick of topping up my radiator fluid. What does everyone recomend/do? Is it just a case of stfu and fill that shit up or get a overflow. Would i need to get another radiator cap if i had an overflow bottle? Im tempted jsut to rangi up some bottle just to catch all that precious coolant that drips out Is it even meant to do this? Quote Link to comment Share on other sites More sharing options...
DavidTheCreator Posted August 27, 2005 Share Posted August 27, 2005 perfectly normal , itll just keep doing it.....you can just go 'fuckit' if you want because itll get to a certain level then stop emptying . or u could 'rangi' up some botlle and get the hose on the rad to go into the bottom of it , then half fill the bottle with coolant , cap should be fine , so long as it has a vacuum cap , (look at the bottm and in the center there will be a flap type thing ) , if it does she'll be sweeeeet mongol Quote Link to comment Share on other sites More sharing options...
SYKOV6 Posted September 1, 2005 Share Posted September 1, 2005 you can get a tidy factory looking overflow tank from supercheap for $10 looks alot tidier than a beer can or fizzy bottle. also check your rad cap as it might be bit sad in the spring/seal area and could be bypassing more than it needs to Quote Link to comment Share on other sites More sharing options...
HUNTD Posted September 1, 2005 Author Share Posted September 1, 2005 you can get a tidy factory looking overflow tank from supercheap for $10 looks alot tidier than a beer can or fizzy bottle. also check your rad cap as it might be bit sad in the spring/seal area and could be bypassing more than it needs to That sounds like the deal... already replaced radiator cap Thanks for the replies Quote Link to comment Share on other sites More sharing options...
Hemi Posted September 1, 2005 Share Posted September 1, 2005 oh yea forgot about my ex work lol , yea they look much tidier Quote Link to comment Share on other sites More sharing options...
zep Posted September 1, 2005 Share Posted September 1, 2005 I have a Sprite Zero bottle. Works a treat, although the water got so hot that the bottle warped :S Quote Link to comment Share on other sites More sharing options...
esky boi Posted September 1, 2005 Share Posted September 1, 2005 Make sure you have a radiator cap with the right pressure rating bro, mine used to have that problem.. Oh yea if it is right but coolant still comes out, then theres probably a little bit too much in the radiator. It'll emtpy out as much as it needs and then its sweet. Quote Link to comment Share on other sites More sharing options...
Guest WESTCORT Posted September 1, 2005 Share Posted September 1, 2005 you can get a tidy factory looking overflow tank from supercheap for $10 looks alot tidier than a beer can or fizzy bottle. also check your rad cap as it might be bit sad in the spring/seal area and could be bypassing more than it needs to fully gona do one with a beer can, ill find me an old db bitter to suit the green of the car Quote Link to comment Share on other sites More sharing options...
