WildPlumDx Posted August 15, 2005 Share Posted August 15, 2005 how do you do it? i oooh its on my ute dont think its eltronic one ? pretty sure or whatever someone explain please! hear its easy? oh as in set up i mean ive pulled it right out... so from start to finish cheers Quote Link to comment Share on other sites More sharing options...
TygerTung Posted August 16, 2005 Share Posted August 16, 2005 Just bung it in when the timing mark on the crank pulley is set to TDC and have the rotor pointing to cylinder one on the dizzy cap, well I think thats what you're asking. Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted August 16, 2005 Share Posted August 16, 2005 that's what I'd do, makign sure tht the bolt slide thingy lines up with the bolt hole, so that you can lock it on place, once you've perfected the timing with a timing light, as to specs caboon said yesterday that 4g63's run 8 degrees BTDC, would imagine that's about right for yours as well... google's your friend to make sure I guess, unless you've got a manual/check to see if the "autokit" sticker's still in your engine bay/on the underside if the bonnet, they usually have the basic sort of stuff like that. Quote Link to comment Share on other sites More sharing options...
Ogre Posted August 16, 2005 Share Posted August 16, 2005 5 degrees BTDC for the 4g54 i would just do as whats been seid.Its kinda fiddly the first time but once you have it right its sweet and you will be able to do it easy. If your dizzy has 1 wire from it then its a not electronic, if it has 2 wires its electronic. Chur that Quote Link to comment Share on other sites More sharing options...
WildPlumDx Posted August 16, 2005 Author Share Posted August 16, 2005 oooh mine has two wires? going into the same place both black does that mean its electronic i guess? whats the diff with those ? set up the same or what? Quote Link to comment Share on other sites More sharing options...
Defcon Posted August 17, 2005 Share Posted August 17, 2005 Those sounds like the wires going to the pick-up- not sure if these dizzy have an external module (usually on top of the coil) should connect to that, No idea bout the misti's tho so cant tell ya which wires they connect to. Electronic means it stays perfect(well almost) where as with points the gap setting goes out after a period of time and u have to re-set them. electric also give fatter spark. Def' Quote Link to comment Share on other sites More sharing options...
Ogre Posted August 24, 2005 Share Posted August 24, 2005 all it does is have electronic advance etc. on wire goes to the - of the coil and the other to the +. Not sure witch is witch tho.If you get stuck i will look at mine Quote Link to comment Share on other sites More sharing options...
lowlancer Posted August 24, 2005 Share Posted August 24, 2005 Cunt, what;s the deal with changing to electronic? Where does extra wire go on teh 63s? Quote Link to comment Share on other sites More sharing options...
WildPlumDx Posted August 31, 2005 Author Share Posted August 31, 2005 oldschool has been donw for a few days with me whats up with that !? anywho still cant get this GAY dizzy to work thought i had it sussed but nup! now i have the front pully on i cant see the timing mark on the crank so dont know where TDC is and yeah basically gotta start from nothing grrr! help!? Quote Link to comment Share on other sites More sharing options...
Hemi Posted September 1, 2005 Share Posted September 1, 2005 itll be there my friend , has to be its a lil chink out of the pulley , if u cant find it then taek the spark plug out and turn ur motor over while u have say a pencil held in the hole ...wait till it gets to the top , there top dead center .....then just slide the dizzy in so that one of the lil points on the rotor points to cylinder 1 ...its shoudl be able to start , then after u just time it up with the light ...sweet as mongol Quote Link to comment Share on other sites More sharing options...
