Guest stephenranks Posted June 3, 2005 Share Posted June 3, 2005 Any one know of any tricks to get 4k's goin quicker that cost little or no money? Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted June 3, 2005 Share Posted June 3, 2005 what ahve uy done so far? Quote Link to comment Share on other sites More sharing options...
RT Posted June 3, 2005 Share Posted June 3, 2005 extractors, cold-air induction, side-gap your sparkplugs um.. MSD Blaster coil, new silicon plug leads, electric radiator fan, clean out your water system.. thats about it for cheap thrills. Quote Link to comment Share on other sites More sharing options...
DavidTheCreator Posted June 3, 2005 Share Posted June 3, 2005 extractors, they go pretty cheap. if your brave bore it out yourself with a dremel Quote Link to comment Share on other sites More sharing options...
Hemi Posted June 3, 2005 Share Posted June 3, 2005 ....get a 5k Quote Link to comment Share on other sites More sharing options...
MAD626 Posted June 4, 2005 Share Posted June 4, 2005 Make sure its serviced and tuned right to start with. Check spark plugs/leads/points/air filter etc are ok first then after that i would go with the extractors, electric radiator fan, elec distributor? Quote Link to comment Share on other sites More sharing options...
Defective Posted June 5, 2005 Share Posted June 5, 2005 if its in a corolla put it in a starlet. if its in a starlet alrready then throw away your interior, spare wheel, jack etc etc. join a local rally club, and buy some old lexan windows, basically make it as light as poss.... not quite what your asking though.... Quote Link to comment Share on other sites More sharing options...
WildPlumDx Posted June 5, 2005 Share Posted June 5, 2005 i got one buy my Z18et nissan turbs for $800 mounted in a Ke70 sedan bug eye (body suit parts) all it needs is loom hooked up and driveshaft and u gotta turbo rolla Quote Link to comment Share on other sites More sharing options...
coltspeed Posted June 10, 2005 Share Posted June 10, 2005 throw a 3K head on it, they have larger ports! Quote Link to comment Share on other sites More sharing options...
ke_25 Posted June 11, 2005 Share Posted June 11, 2005 only the 3k-b heads have larger ports.... Quote Link to comment Share on other sites More sharing options...
Ned Posted June 11, 2005 Share Posted June 11, 2005 whats it in? dont bother with the 4k, 5k's are cheap as and give a bit more power thenm the 4k's. good luck Quote Link to comment Share on other sites More sharing options...
Guest Go_the_mini Posted June 12, 2005 Share Posted June 12, 2005 put a 2k head on it, they have a higher compression Quote Link to comment Share on other sites More sharing options...
Ned Posted June 12, 2005 Share Posted June 12, 2005 my 4k has a mad as compression! ask logan, he was there when we did a compression test, just cant remember how high but they were high Quote Link to comment Share on other sites More sharing options...
AE25 Posted June 12, 2005 Share Posted June 12, 2005 from factory specs a 5k have more torque.. not power. which is better for acceleration in normal rpm range. so yeah a 5k would be a nice upgrade. i believe 3k-b has the most factory power. no 3k-b are not the only big port! alot of ke20 3k have a single carb bigport head. my factory 3k-b ('75 ke25) is a smallport twin carb... many variations aye. also swapping heads round willy nilly can bugger things up. there're many differences in the chamber design and piston dish. sometimes ya can end up with 13:1 compression or something stupidly low. later jdm 4k like after '83 have a twin squish head and dished pistons.. early ones have flat pistons and more cc in the head chamber... different pushrod heights.. yada ya. unless you know what ur doing.. then better off skimming the std head or getting a thinner gasket etc to up compression and maybe do some mild porting to get er flowing. imo first thing after a tune up (plugs, fluids, filters, cap, rotor, points, timing, blah, is replace the peeshooter exhaust with 1.3/4 - 2". put a foam or oiled filter on it and some cold air ducting from the front wouldnt hurt. electric fan. cams and heavier valve springs make some good gains after exhaust and intake done. and yeah raise compression. can upgrade carb to something slightly bigger. could lighten flywheel for some better acceleration.... the usual shit. speed cost money, how fast you wanna go? Quote Link to comment Share on other sites More sharing options...
