Guest 78lancer Posted February 7, 2005 Share Posted February 7, 2005 ok so i no u can b legal lowering up to 2" on blocks but were can i get sum?? do u realy need the locator thing on the bottom or can u just stick in a flat block of metal and u-bolt it up tight?? Quote Link to comment Share on other sites More sharing options...
Guest Deton8 Posted February 7, 2005 Share Posted February 7, 2005 ok guy onm trademe sells them but i found a cheaper place: magoo's street rods in masterton.... trade me ones are like 80 bucks.... masgoos are 30 bucks for the smae thing... and ull know theyre good quality if they sell them http://www.magoos.co.nz Quote Link to comment Share on other sites More sharing options...
kyteler Posted February 7, 2005 Share Posted February 7, 2005 okguy onm trademe sells them but i found a cheaper place: magoo's street rods in masterton.... trade me ones are like 80 bucks.... masgoos are 30 bucks for the smae thing... and ull know theyre good quality if they sell them http://www.magoos.co.nz Dude, are you sure?? Taken from the magoo site; Spring Lowering Block Kits (1", 2" & 3") $80 kit Quote Link to comment Share on other sites More sharing options...
Guest Deton8 Posted February 7, 2005 Share Posted February 7, 2005 shit the ones i got for the superminx were only 30 bucks.. they were 2"drop my bad!!!!!!!!!!!!!!!!!!!! the magoos ones r $80 bucks just buy some longer u bolts and get an engineer to cut u up some blocks... saw a dodgy on the oher day someone came into the aluminium wnidow and door factory next door and got some squere shaped ali for lowring his car..... an old falcoon not too unlike that of RT's.... painted primer black Quote Link to comment Share on other sites More sharing options...
Guest WESTCORT Posted February 7, 2005 Share Posted February 7, 2005 trademe ones with u bolts are $130 pedders suspension in new lynn apararently $100 (with u bolts and shit) Quote Link to comment Share on other sites More sharing options...
lowlancer Posted February 7, 2005 Share Posted February 7, 2005 I got my leaves re set 2" and I'm about 1 cm off bumps, and the giard is miles above the tyre. Tell me how you go, cos I'm gonna have to mod my bumps to really lower it Quote Link to comment Share on other sites More sharing options...
Guest WESTCORT Posted February 7, 2005 Share Posted February 7, 2005 bro that sucks aye 1cm off bumps and the guard is still above the wheel, maybe just get some tyres with a huge profile haha.. ive seen replacement eurathane bump stops i think, only for an escort though Quote Link to comment Share on other sites More sharing options...
Draizuh Posted February 7, 2005 Share Posted February 7, 2005 i think its just something about the moleste that makes it look high. like celica GT-4's Quote Link to comment Share on other sites More sharing options...
lowlancer Posted February 7, 2005 Share Posted February 7, 2005 Wait and see! Quote Link to comment Share on other sites More sharing options...
Guest Razor Posted February 7, 2005 Share Posted February 7, 2005 if you want it done the right way get it reset if you want something cheap and face consequences then you can take the smallest/shortest leaf and put it on top of the longest one and turn it the other way around, this will give a lowered effect depending on your shocks condition as well. Be extra carefull taking your leaves off may cause serious injury. in my opinion 3rd will be lowering blocks just doesnt trust this from people who used it and experienced it. Quote Link to comment Share on other sites More sharing options...
Will_8v Posted February 7, 2005 Share Posted February 7, 2005 SAS in Manukau do sets for $70 or so. Quote Link to comment Share on other sites More sharing options...
Guest 78lancer Posted February 8, 2005 Share Posted February 8, 2005 i reset mine bout 4 months ago and there no clearance between guard n tire but now wit 15's with lowerprofile there bout a finger, but it looks low( bout 2cm off bumps), lowlancer ill put up a pic 1 day of nu wheels, but 4 my leafs i pulled middle 1 with no rebound clips out, left top and second normal and flipped bottom 1 upside down on top and did up clips and its been perfectly fine! so ne way can u just use a flat blck with no locator? Quote Link to comment Share on other sites More sharing options...
Guest WESTCORT Posted February 8, 2005 Share Posted February 8, 2005 what problems have people had with lowering blocks? Quote Link to comment Share on other sites More sharing options...
Pushrod Posted February 9, 2005 Share Posted February 9, 2005 Blocks can promote a bit of axle tramp under load but Ive never really noticed Quote Link to comment Share on other sites More sharing options...
esky boi Posted February 10, 2005 Share Posted February 10, 2005 ESCORT POWER wrote: pedders suspension in new lynn apararently $100 (with u bolts and shit) Yup thats right, I rang around heaps of suspension places in auckland and pedders were by far the cheapest. Everyone else was selling them for around the $150 mark. However with the blocks they gave me, the locating holes were way too small, so I had to get the bottom holes drilled out to fit the mount on the spring retaining plate. And on the top I just made the mount bigger by fitting a thick washer with the same diameter as the mounting hole on the diff. It cost like $20 to get them drilled out. Pushrod wrote: Blocks can promote a bit of axle tramp under load but Ive never really noticed Yea I've heard about that too, my esky is on 2" blocks and I can't really notice any difference either. But anyway, im gonna look at getting my springs reset at some stage anyway, where is the best place to go in aucks to get them done and how much does it cost roughly? Quote Link to comment Share on other sites More sharing options...
esky boi Posted February 10, 2005 Share Posted February 10, 2005 Oh yea, and you do need the locating holes, otherwise when you fit the diff it wont sit straight .....Another thing, when you do the U bolt nuts up, tighten them EVENLY and dont do them up past the recommended torque. If you dont use a torque wrench do them up until they feel tight, but once they start to get no tighter STOP tightening them or youll strip the threads. Trust me, its very easy to do, my mate wouldnt listen to me and he was like nah bro its sweet, they need to be tight as, and...... he had to learn the hard way... Quote Link to comment Share on other sites More sharing options...
big tymer Posted February 12, 2005 Share Posted February 12, 2005 why dont you just make your own i mean it is only a block of metal Quote Link to comment Share on other sites More sharing options...
jinx Posted February 12, 2005 Share Posted February 12, 2005 so is any cam gear or oil pump - ready to file up a new one of these are you? Buying them gives you (generally) a better product, designed to do the job, and with the correct attachment parts. Modification of the locating holes/pins is quite common as there are so many different types out there that they only make a small number and leave it to the shop or buyer to modify to fit. Try pricing up new diff U-bolts and you'll soon see that most of these kits are pretty cost effective. Quote Link to comment Share on other sites More sharing options...
big tymer Posted February 12, 2005 Share Posted February 12, 2005 nah cheaper to make takes abit of time but thats the whole point of it not just to slam your ride down 2" Quote Link to comment Share on other sites More sharing options...
4AG_Addict Posted February 12, 2005 Share Posted February 12, 2005 Yup thats right, I rang around heaps of suspension places in auckland and pedders were by far the cheapest. Everyone else was selling them for around the $150 mark. Man You Aucklanders are getting a Raw deal, spring makers in Christchurch sell them for $50 a set with U-Bolts! Quote Link to comment Share on other sites More sharing options...
