Understeer and Swaybars
zep
Ok, my car seems to be understeering a bit when I take corners hard. It still has the stock sway bars in it. If I upgrade these to heavy duty ones, will it cure my understeer problem? I will be doing some nolathane bushes in there too.
How much toe-in can you give your car? That might help a little... or get some better rubber up front.
as far as I understand understeer is caused by traction up front being lost and momentum taking over. Solutions: more traction (wider or better rubber), more weight up from (pig iron over coils :D), or lose some traction at back (put 155 bickies on the back!)
lol
If your car is understeering already from what I know putting in a HD sway bar with only make it worse the front will be nice and stiff but understeer may still be a problem you can increase the front track and increase the negative camber which should have the effect of promoting oversteer :D
I think anyway correct me if im wrong :?
Guest B.I.G Developments
when was ur alignment last done? increasing track width can help. If you toe-out too much it can cause stability problems travellin at high speed in a str8 line. sway bars will help with cornering but i don't think it wil fix ur problem fitting nolathane bushes has the same effect as a swaybar 2mm larger in diameter i would recommend getting ur alignment checked before u do anything and have all ur suspension components checked for wear also. go to somewhere like the shock shop. the one on station road in penrose is good they know what they are talkin bout down there
The Shock Shop
Alignment Specialists
137 Station Road
Penrose
09 579 5246
for all ur suspension and alignment needs.
Logan and I did replace the front springs and shocks the other day, which could have fucked with it a bit. I haven't had my alignment done for ages so I'll have that done soon.
Yeah, it just feels as if there isn't enough weight at the front when cornering fast (if anyone has ever driven up the road from the Chelsea Sugar factory, that big corner allmost killed me the other night).
I have new shocks and springs all round, just gonna do the bushes sway bars and panhard rod to finish and hope it's all good.
Guest WESTCORT
speaking of bushes i got quoted 360 for a full set of nolathanes for my escort at pit stop. anyone else ever had a cheaper quote? by the way its 360 just for the parts and if i wanted them to do it which i dont it would be an extra 366 rahahaa
Guest escort_boy
PM rich(big developments) he'll hook you up if you hook us up with those banners. He can get them so much cheaper.
banners??? am i the only confused one??
Alex knows what banners i'm on about. what i meant was, rich can get all suspension shizzle cheaper so see him. and in return alex can hook a brotha up with those banners i wanted
Yeah bro. I'll be there. Rich will get a price for you tomorrow. when you say full se t what do you include in there?? swaybar bushes.... linkarm bushes...How many bushes??just for the front?
Guest WESTCORT
i mean all the bushes in the front and back, i told the guy at pit stop give me a price for all the bushes in my suspension front and back and he said 360 but yeah anyways we can sort it saturday
