Guest kornstar Posted December 6, 2004 Share Posted December 6, 2004 what are the factors that make it hard or take a while for a car to startup? And when i start the kingy up, when its cold it spits out a bit of black oily shit, but only for a few mins when it warming up, wtf is the cause of that? and how can i fix it? Quote Link to comment Share on other sites More sharing options...
Guest WESTCORT Posted December 6, 2004 Share Posted December 6, 2004 if you havent got the point gap very accurate it can be a bitch to turnover when starting it Quote Link to comment Share on other sites More sharing options...
Guest Jamezuu Posted December 6, 2004 Share Posted December 6, 2004 Carby mixture a bit lean, timing out or incorect point gap are most common. Get a bit on fine sandpaper and give the points a clean up, or turning the mixture screw out a tad. Quote Link to comment Share on other sites More sharing options...
lowlancer Posted December 6, 2004 Share Posted December 6, 2004 Its just water mixed with carbon, one of the by products of the engine. It builds up overnight etc, then comes out the end when you start Quote Link to comment Share on other sites More sharing options...
RT Posted December 6, 2004 Share Posted December 6, 2004 Pull off the holden badge and replace it with a ford..maybe that will help just kidding. Black watery shit out the back doen't matter, the water means complete combustion which is a good thing. Also dirty plugs can be a factor causing a bitch start. Probably a bit rich too... Quote Link to comment Share on other sites More sharing options...
Toucan Posted December 7, 2004 Share Posted December 7, 2004 Yea what everyone else said bout the black shit, you burn a litre of gas an you make X amount of water. Umm, new piston rings = heaps of compression = harder to start... havent put new rings in it lately have you Quote Link to comment Share on other sites More sharing options...
Guest kornstar Posted December 7, 2004 Share Posted December 7, 2004 not when ive had it, and i no the previous owner didnt, it just turns over for ages like its waiting for fuel or something, ill give the plugs a good clean and see if that helps. Quote Link to comment Share on other sites More sharing options...
Guest FUKD50 Posted December 7, 2004 Share Posted December 7, 2004 my car. sum mornings it wont start unless i gets jump started. duno why. other mornings you turn it over for ages then at the right time you stop turning it over then put youre foot on the gas then like a second later it starts. without turning it over. i dont know. its weird Quote Link to comment Share on other sites More sharing options...
lowlancer Posted December 7, 2004 Share Posted December 7, 2004 Get new leads and plugs fukd50 Quote Link to comment Share on other sites More sharing options...
Toucan Posted December 8, 2004 Share Posted December 8, 2004 Umm, new piston rings = heaps of compression = harder to start... havent put new rings in it lately have you Twas a joke but anyway... Maybe you need a new battery to give the starter more balls. I got no choke an I still get it going in the mornings fine Quote Link to comment Share on other sites More sharing options...
trunk-rattlin Posted December 8, 2004 Share Posted December 8, 2004 dont use choke either. just one pump of gas and start it, when the starter motor noise goes higer pitch, then give a few more squirts of gas. then vroommm vrom vrom vrom vrom vrom............lumpyness Quote Link to comment Share on other sites More sharing options...
Hemi Posted December 8, 2004 Share Posted December 8, 2004 my choke is weird it dont have choke plates lol it a 28/36 dcd off a 1500 corntina i think?? anyhow my new engine is a bitch to start over because of the brand spanking new rings lol , otherwise it take two rotations of the starter then braap brap brap three cyinders for a few moment then it idles nice and smooooooth , tends to run on for about 4 seconds after i turn it off though bahahaha Quote Link to comment Share on other sites More sharing options...
Jerm Posted December 8, 2004 Share Posted December 8, 2004 if ti runs on that bad its better for your engine jus to put it in 4th and stall it Quote Link to comment Share on other sites More sharing options...
Guest WESTCORT Posted December 9, 2004 Share Posted December 9, 2004 sometimes my engine runs on so long people think its the turbo timer; i tell them how its under the dash and is top of the range Quote Link to comment Share on other sites More sharing options...
lowlancer Posted December 9, 2004 Share Posted December 9, 2004 hahaha holy shit, and I though cortinakids hunter was bad.... Quote Link to comment Share on other sites More sharing options...
trunk-rattlin Posted December 9, 2004 Share Posted December 9, 2004 what octane gas are you using escort power Quote Link to comment Share on other sites More sharing options...
Guest WESTCORT Posted December 9, 2004 Share Posted December 9, 2004 diesel Quote Link to comment Share on other sites More sharing options...
lowlancer Posted December 9, 2004 Share Posted December 9, 2004 haha fuck I laughed at that Quote Link to comment Share on other sites More sharing options...
