Everything posted by jakesae101
tis about 370 for a "stage one kit" that comes with 1 nozzle a check valve pressure switch pump relays and t pieces connectors ec not bad value couldn't come up with a cheaper one off ebay i did look into buying the kit of ebay the dude on trade me sells and i couldn't get it any cheaper
the sureflow pump its a aquamist kit the .pulley i run spins the sc at max rmp its capable of at redline its a custom jobbie bigger than anything off the shelf
the only other issue i can forsee is that if i run direct port and pre supercharger it woul strain the pump too much trying to supply that many sprayers. i was think ether triggering it at over 5,000rpm or over 10psi boost pressure
my mate who uses it on the orange ae82 fxgt in targa recons he uses only 5 litres between service parks
its not really a road car anymore its road reg but never gets used on the road , i had looked at a port injection setup and think i could squeeze it in i just want to lower charge temps as well as some anti detonation protection as the supercharger makes the charge air bloody hot. was considering a pre supercharger nozzle to help cool the rotors of the supercharger
not really the stage one kit comes with a adjustable boost switch so you can get it to come on whenever really . never heard of it damaging internals of a engine tbh its such a fine mist of water that it atomises like fuel into the combustion chamber
Yoeddynz's 1985 Hino N0915 housetruck build.
jakesae101 replied to yoeddynz's topic in Project Discussion
have to check the regs again its been a looooooooooong time since ive done one basically id be looking for earth bonding to the chassis. and require some sort of fusing / breaker setup if you need to know anything specific just pm me and ill find out. and id want to check out the 230v wiring setup inside / inverter wiring at the end of the day it is my name on the paper so i have to cover my ass as im personally liable -
so the 4agze in the trueno is as far tweaked as it can go on the standard i/c setup. so in hopes of making more power im going to change to a small front mount with short 2inch piping. and run water injection in the hope to run a bit more advance and have cooler inlet temps . currently runs 15psi standard top mount and a fuel controller and makes over 120kw as is anyone used water injection before what were your experiences ? and before anyone says it yes i know a aftermarket ecu would be the go but im far to jew with my moneys to fork out for it (lets face it who isnt here ) i have made not bad power with my fuel controller up untill now
if you bring it to wellington ontop of meeting all the epic gcs here ill do you a free electrical wof on the camper if you need one -
DRFVDR's Project ANARKY,1986 Subaru Omega RX11 Coupe
jakesae101 replied to DRFVDR's topic in Other Projects
heh it looks pretty sweet with gravel tyres i was with jason when we got those parts off you for viv -
well i finally got onto doing some work i forgot to say a month ago i setup a new intake from the inner guard but may change this again soon to air from the scoop if i change my inter warmer setup today i finally changed the dirty old cast exhaust manifold to a blacktop 20v extractors a rather easy upgrade really i linned up my new 16v gasket and re drilled the end 2 holes as it turns out the 20v 2 into 1 fits into the ae92 so i didnt have to cut and weld anything there when it came time to fit the primarys i ran into a snag i had to cut part of the manifold and heat shield tabs that wasn't needed now as it was hitting the CAS ended up looking like this also exhaust bolts are a cunt to remove after never being undone there was lots of skin removed from my hands tonight i also discovered that the ae92 and ae111 oxy sensors have a different bolt spacing so i had to slot the holes ended up with a snug fit that looks like this as you can see its a rather snug fit with the CAS just ordering some goodies a water injection kit , civic half size radiator and looking at a better intercooler setup to gain some moar power
Welly Meet - First Thurs of the month - 7pm - 6th October
jakesae101 replied to KKtrips's topic in Lower North Island Region
pretty sure its copper joined to plastic under the lawn somewhere and the joint has let go just wack a starkie in it and it would be all good id say but at this time of night i dont think so -
All good Corbie was worried that you hadn't turned up - but Beaver took him in for the night - bless his soul. flatmate rung me and was like oh theres a wee bit of water comming out of the lawn i get home to find a new water feature flowing a good 30L a minute plus creating a big sink hole on the lawn -
shit im rather gutted i couldn't make it had a call out for work then had the small issue of a burst water main at my flat to deal with -
possibly you can stay on my couch? -
seems like there is a bit of pitting round the bore if it was me id get the block decked and head skimmed to make sure the sealing surface for the gasket is 100%
its on the first page man -
oldschool peeps cruise to horopito - 18th June
jakesae101 replied to DavidTheCreator's topic in Lower North Island Region
id be keen if i can get a ride i love that place -
yea head is with him just been to lazy to go get it again i really should however
Does anyone know what the the V.E. is for a stock pinto?
jakesae101 replied to RUNAMUCK's topic in Tech Talk
i have that book also its got a whole heap of good stuff in it -
Where to buy short lengths of steel? - Welly
jakesae101 replied to vivaspeed's topic in Lower North Island Region
try metalworx in town have brought short lengths from them before -
was a 4 speed escort box was a 1600 with sidies and a cam and some headwork exhaust ect nothing radical was 4 years or so ago now we put a quaife straight cut close ratio gear set in after that happened
E Class A (ATV Reg) FAIL SAGA : why not to try etc.
jakesae101 replied to JoKer's topic in Tech Talk
they may say something at a rally they may not some regs say you have to have a wof also -
that looks rather familiar we did the exact same thing with a race car i was evolved with at manfeild
pretty much suicide shifter is a must
