Everything posted by Horse25
Your Jeep is looking awesome! Mates got a Jeep wrangler, 9inch lift kit etc
the factory ones are crap, made of ali and always break! I went and got brass fittings, think they were about $3 each. Take your hose in with you as there are different sizes. If the plug has snapped off inside just use a screw driver to tap i out, be careful not to damage the thread!
yeah that can be easily done to pour that amount of money into it. I was pretty tempted myself to buy it, just for the new parts in it!
two_days_late's 1980 MK2 Escort Sport
Horse25 replied to two_days_late's topic in Project Discussion
looks good! That starter motor conversion is the best $120 i ever spent, could properly do it cheaper if you know what honda to get the starter motors out of. I haven't touched my sport since i thrashed it a few months ago haha. Will you get this on the dyno? -
yeah that white wire should do that, what's it like with just one head lamp running? two might be too much? what's the voltage across the battery when they are both on and its running?
Battery acts as a regulator, you will blow the lamps other wise But looking at the diagram again its hard to tell what is switched to what in the "headlight switch block"
just connect it into the yellow somewhere with a switch on it, and with the x2 front a rear on it will make them brighter. Doesn't help on dons bike that the carb intake is facing forward haha
The DC from the rectifier straight to the coil, the battery is just connected in parallel to this anyway. I should properly check what its putting out from the rectifier, too excited with getting it running. Got the bike going a lot better today with an airfilter pipe on the carb, which creates the vacuum in the carb or something, But idling without anything on the accelerator cable it would just randomly rev up and then just die haha. any ideas? So what colour is the wire that comes from the engine that puts out 3v?
we had dons ct90 going yesterday with no battery, going to put it back in as per the wiring diagram though
What colour is your wire from the engine? is it white? If you go back to the wiring diagram you can see that the head lights are run off the battery. Also if the wire is white it looks like it gets connect into the yellow wire from the engine when the lighting switch is turned on to boost that circuit. You can run this bike without a battery it just means that it would blow your bulbs all the time as it not regulated like Sam said.
yeah if it was stock that's what i was thinking but could always change the jets etc? I think it was around the 200ish mark to get it tuned there. ive had it done there twice in the last two years.
palmside tuned the 45's on the 2.0L i have, What work have you done to the 2.0?
have to work on this weekend now, will pay for some parts for my RD though!
im keen to head down. Anyone else?
Turns out they are 4x110 which makes sense now. They fit but i was told the studs have a chance of breaking so wont end up using them unless i get adapters and if im going to do that i might as well go 4x114. Bit of a bummer but oh well. Do i Sell them or Keep them? They are Sharak x-1x http://page6.auctions.yahoo.co.jp/jp/auction/f112753985 (few sets on there just not 4x110) I don't have a spare bonnet sorry
Yup i can take you for a spin, Needs a clean etc. dont think 13x9's will fit under the guards, but can only try! Does any one know much about the wheels, Says made in Japan, Sharak x-1x. I looked them up on yahoo and they are only selling them in 4x114 I need one more! have a set of these that are being polished cheers to Ridal and then painted
Yeah? or Nar? Only got 3 of these doubt i will find another with the same PCD Discuss viewtopic.php?f=18&t=20005
sweet that's good news!!
properly heaps of other shit i should update on this but for now
ha yeah finished exams for now, Haven't driven my white one in about a month, don't think its me
ill be there
One of the guys at Palmside was showing me a mk1 four door he was selling, it might be still there give them a call, they are open on sat mornings as well, they should be willing to help you out.
only the one, car struggled to tech with it hardly snowing this morning, glad i made it home once tech shut at 10, this is taken about 10mins after i got home
hey if you sell that dizzy let me know Or talk to Peter at Quality Rebuilds, knows his stuff, he can properly modify it for your application, also i have a side entry cap for your dizzy which is no use to me, I had problems with the dizzy cap fouling the manifold/carbs so i ended up going with a 1300 manifold which clears it. Also using a genuine Lucas dizzy that Pete built for me, wasnt cheap! http://www.qualityrebuilds.com
I tried it with a T9-5 speed, left it over night to drain in as it was taking ages, then the next morning i had a big puddle of oil under the car, had drained out the backing plate, so you cant do it with T9, but four speeds maybe different, i wouldn't risk it.
