escorted
Everything posted by escorted
  1. I think it has alot of speed bumps
  2. If all else fails try chris at suspension tech. He knows mounting escort engines backwards
  3. Yes you need a cert and yes you need a drive shaft loop It needs to be 6mm plate. As for the clutch cable you can buy one new from Repco for the sum of $60 Cheers, Matt
  4. I have decided to run some twin side draught carbs on my pinto powered escort and was wondering if the standard fuel pump is up to the job? Carbs are 40mm Dellortos. Cheers, Matt
  5. Would it hold together long? How close to the water jacket?
  6. 1600 will Pinto you need to swap the brackets around
  7. I running my 1300 radiator at the moment. Its not exactly perfect so i would go with a 1600 or A pinto 1
  8. keen. was fun last time
  9. Id rather go a 1600 than a pintho. Less work and can return to factory easy
  10. Either that or get it Re-calibrated
  11. Are you gonna get it done in time?
  12. Or even a Rover V8
  13. what about a V8? 289?
  14. Also reccomend putting the fuel line up the intake side of the car to avoid nasty fuel line on exhaust manifold stz
  15. Pinto cams are also a bastard to set the valve clearences
  16. Will def be there!
  17. Foodtown probly bigger. What the other NS peeps think?
  18. Keen. Wheres a good place to meet for NS convoy stz?
  19. I would do it for A box of beers but i dont think i could swing it in my lathe. But a good engineer/turner could get it done in under an hour
  20. Looking flash. Owen Evans reccomended then?
  21. / car pool - Start in the shore. Im glenfield. Also instead of burger fuel why dont we have it some other place that is central and has parking???? But in saying that im keen for anything anywhere. +1 im in Hillcrest/Glenfield
  22. going to go for Air bags?
