Everything posted by cletus
Put the other distributor in, now has vac advance again. Runs a bit better, I'll see if its more ecom on pertol over the holidays I managed to pull the ends off 2x leads swapping them over which is a pain in the bum, a couple looked a bit manky in the ends so ive ordered a new set off my favorite supplier of parts. Who, it appears, sort out the GST issue at purchase so no problems there.
- 61 replies
Definitely dont get any blasting on the shaft and try and keep it away from the seal also Have seen a few get ruined by underbody sandblasters
The way I read it, if Chevron is the manufacturer and that is the style of belts it had fitted originally, it meets note 18 (a) on the page @AllTorque linked So if you can get something from them proving thats what they had for belts originally, it should be sweet I assume it has no cert plate?
I drove a van with a 1uz in it once that had had toothed pulleys/extreme gilliez put on all of the accessories Goodness me it was noisy. RRRREEEEEEEEEEEEEEEEEEEEEEEEE It must have cost a fortune to make it all work.
Hi David . I like that red. However I have noticed a technical issue that I'm not sure you have noticed Your supercharger pulley ribs go the wrong way! Also I cant see where your carburettors are going to go or where your mr garlits 3 hole fake scoop is. Regards, Clinton
- 541 replies
So good to see it out getting used. Do those transmissions have a kick down cable or is it all electronic?
J.e.d.'s 1963 Ford Galaxie Hardtop Discussion
cletus replied to The Bronze's topic in Project Discussion
I've been tempted by a couple of cars recentlyish, but would mean selling my VG, and the main thing that puts me off is dealing with idiots and I just cant be fucked with them Good luck, hopefully the sort of car it is minimises the amount of chumps you have to deal with I'll keep an ear out for anyone after one -
Would need to go through design approval process http://www.lvvta.org.nz/shop/chapter-4-build-approval-process/
Have you tried advertising anywhere other than here? It seems to me that would be a steal at that price, 2 door, and a good year -
2x sets of wheels cert requires road testing on both sets so you would need 2 full sets Thread sticky outness looks ok to me. The 2 threads rule is meant for nuts, not necessarily threaded holes in things
Ha Left it till the last minute before drag day, finally got around to getting some 50 thou shorter pushrods 5 years later. Put them in tonight but a bit late for road testing and waking up all the neighbors, but it did start, and didn't rattle Also rock auto to the rescue again, got a distributor with a vac advance so in another 5 years I might get around to putting it in
- 61 replies
- 25
I always leave the auto adjust thing out of valiant brakes too Also I'd be wary of changing shoe linings away from what size you have, you might find someone has gone to a narrower shoe to prevent the rear brakes locking up
Te Urewera Undertaking, 2019 Nov 29th, 30th, Dec 1st.
cletus replied to johnnyfive's topic in Upper North Island Region
@sentra might have it? -
- 895 replies
- 16
- 895 replies
- 895 replies
- 23
Heck yes that was great fun. I had a million percent better time this year with a bike that wasn't a complete turd Big thanks to J5 and the support vehicle drivers for making it all happen And stoked with this thing for hauling me and my junk all over some pretty rough roads with zero issues even with a decent helping of dust and mud everywhere. I lost count of how many oh shiiiit moments I had on gravel including coming within a couple of inches of driving off the side of a cliff while looking at the scenery but managed to avoid any incidents- 895 replies
- 17
I thought @Thousand Dollar Supercar idea of going to see that ford vs Ferrari movie was a good one
Depends on the car, some are on the buckle end, some are in the retractor, but either way still has to function
Is it for a civic? Might be easier to swap whole disc rear hubs in?
Also need to make sure theres enough material at the stepped part. Have seen some where there is very little actually attaching the 2 parts together
Closest I came to falling off was trying to keep up with Bort on a downhill section I thought 'if I keep this up I'm gonna die ' so gave up Just after that was the gn vs dio incident -
Dunno, I think I'd need to run it up the other way so the pipes work, and the inner guards taper in at the bottom so theres not as much room for bends etc
Hmm, decent radiator fans would help as well to get the air moving over it
