Everything posted by sheepers
shit i forgot to post the pics of the seats and carpets all done. lol, that was ages ago. 2021-08-12_06-31-20 by sheepers, on Flickr 2021-08-12_06-31-12 by sheepers, on Flickr 2021-08-12_06-31-02 by sheepers, on Flickr 2021-08-12_06-30-52 by sheepers, on Flickr
i went back to the dyno with the new intercooler and well, sometimes it doesn't go your way. had many small issues throughout the day, in the end the fuel pressure started doing strange things right at the top end so we had to pull the pin. so at the end of the day i had a semi broken car and i was two grand lighter in the pocket which always make a bad day at the dyno even better. took the fuel system apart and couldn't really find anything obvious so i threw LOTS of money at it in the hope that it will be fixed. both pumps are new, two new larger fuel filters, much larger surge tank, new FPR and new injectors. the other thing im going to do is move the oil cooler because it had trouble getting rid of coolant temp. the oil temp and inlet air temps were perfect but the water was getting hot and it took a long time to come back down. 2021-11-12_07-03-34 by sheepers, on Flickr
- 145 replies
- 24
love your work mate, great job!
exactly! you can see the predicament I'm in.
Yea neither tbh.
totally forgot to post the finished pictures. sorry, i finished this a week ago. 2021-10-25_04-07-31 by sheepers, on Flickr 2021-10-25_04-07-45 by sheepers, on Flickr 2021-10-25_04-07-51 by sheepers, on Flickr 2021-10-25_04-07-59 by sheepers, on Flickr
- 145 replies
- 48
righto so i wasn't happy with the left side of the spoiler so i cut it off and made a new one. i was really happy with the fit and the shape so i went about finessing the thing to get it how i wanted it. i radiused the bottom corners and went about making it stronger, i welded a couple of bits of 1.6mm thick sheet all the way along the bottom edge to stop it flopping around then i set about making a good mounting for it. i ended up welding a bit of 3mm plate to it that bolts to the bottom of the intercooler bracket so its pretty strong. then i put another bit of 1.6mm sheet right across the lowest most forward point in the hope that when i inevitably crash it into something its got a bit of strength to it. then i put a coat of primer on it. and today i sanded it, put some bog on it and put some more primer on it. tomorrow ill wet sand it and put some colour on it and its finished. also this is the english wheel i bought. i wouldn't know a good english wheel from a fucking sandwich but this one worked for the thing i did and i was really happy with how well i was able to make the steel do what i wanted, so yea. 2021-10-20_07-24-20 by sheepers, on Flickr 2021-10-24_03-00-29 by sheepers, on Flickr 2021-10-24_03-00-39 by sheepers, on Flickr 2021-10-24_03-01-06 by sheepers, on Flickr 2021-10-24_03-00-55 by sheepers, on Flickr
- 145 replies
- 32
they're good. no noise that i know of, but tbh this car is pretty loud so yea, take from that what you will. tbh if they made pilot sport 4 in a size i could use on the back of this car id swap tomorrow. pilot sport 4 is the best tyre ive ever had by a long long margin.
time to make a front air dam for this thing. its only been needing one for 16 odd years so I've really not hung around on this. i bought an english wheel and a bead roller, neither of which i have any idea of how to use but you gotta start somewhere. so i made up a wire frame using 3.2 dia welding rods then put some cardboard on it. i used the cardboard as a template to cut out some steel then i went about wheeling a tiny bit of shape into it just to give the pieces some rigidity. with some folding, some beating with a mallet and a bit more rolling i ended up with what you see below. for a first time doing this im fucking amazed at how good it is, im really happy i was able to get the shapes i did without fucking it up too much. having said that im going to start again with the sheetmetal and make another one. i learned heaps just making this first one and i know i can make the second one better so i will give it a go. 2021-10-20_08-03-54 by sheepers, on Flickr 2021-10-20_08-03-48 by sheepers, on Flickr 2021-10-20_08-03-40 by sheepers, on Flickr 2021-10-20_08-03-31 by sheepers, on Flickr
- 145 replies
- 35
i like how you've set this up so the first time you crash it not only is your nut sack your air bag, you get 3rd degree burn to the scrotum to add to the fun. well done.
yea me too. ive got the last pieces of the puzzle on the way then itll go back on the dyno for a quick tickle and ill see what difference it makes.
forgot to post these. first is R32 GTR intercooler core design. second is plazmaman core. 2021-09-28_06-56-17 by sheepers, on Flickr 2021-09-28_06-56-26 by sheepers, on Flickr
- 145 replies
- 17
i ordered a new intercooler ages ago but it was coming from auz and they went into lockdown right when i ordered it so it took 3 months instead of 3 weeks. anywho it turned up and i went about making it fit. its wider but not as high as the one that was on the car. a quick note about the intercooler that was on the car. its an R32 GTR intercooler that i put on the car about 2007 and it has been through hell and back and it took it all. it stoved the side of Spencer's soarer in, its taken literally hundreds of hits into curbs and driveways and fucking all manner of shit and its never had a leak or a broken tube or anything. this thing needs a place in the hall of fame. so yea, new intercooler will flow WAY better than the old one and the dyno will tell the story. i made a new bracket thing to hold the cooler and it had two mounting holes on the bottom but because i cant use the top ones i thought id add two more to the bottom just because. i only had a small piece of square aluminium so i made it round and welded them on. 3the new intercooler sits about 30mm higher than the old one too so thats a good. at some point imma make a front air dam for this thing. 2021-09-25_06-12-31 by sheepers, on Flickr 2021-09-25_06-11-50 by sheepers, on Flickr 2021-09-25_06-11-58 by sheepers, on Flickr 2021-09-26_05-10-21 by sheepers, on Flickr 2021-09-26_05-10-43 by sheepers, on Flickr 2021-09-25_06-12-12 by sheepers, on Flickr 2021-09-26_05-10-37 by sheepers, on Flickr
- 145 replies
- 33
ive got a pedal but i don't use it. if you set up your down slope to suit the job you can lift off the trigger and decrease current/heat that way. that's the way i do it, works well for me.
what a rip off. just do what that guy is doing and buy the kits off aliexpress.
sheepers replied to tomble's topic in Project Discussion
using the forum to host multiple pictures isn't the best idea. I, and I'm sure many others, cant see any pictures in your thread because they take way to long to load. some people might wait for them to load but it takes ages. just letting you know. -
fuck im stoked for you man, great work!
its about 610 ftlb at the wheels.
fouling underwear is a given i think sir. and ill foul them with glee as i attempt a full depression of the accelitratornix i tell you now!
Yea Probably. I unno. I do know that she's gonna be a hand full I tell you what
It's 600 but who's counting.....
