Raizer
Everything posted by Raizer
  1. Did anyone see the letter/email in the last fast 4s mag asking for prizes etc for this "comp"
  2. I dont know about the aussie capris but all the English V6 capri's used a atlas type rear end and so did quite a few of the 2Ls and all mk3/4/5 cortinas
  3. With 10" Wide Mini-tubs... yup. So your going to have trouble keeping the front tyres on the ground then!
  4. Normally you should be able to take the lock out of your drivers door, take it to a locksmith and they can cut a key from a code stamped on/cast into it. Had to do it with my escort and a few cars at my old work, doesn't cost much more than just getting a key cut.
  5. Bike carbs FTW! Used on crossflows a bit in the uk etc
  6. Gisborne car isnt it? If not it had a twin here
  7. Dont you have to slightly slot a hole for the auto shaft to fit? Not if you use the flange from a mk1 diff head as well, or get a new uni joint and have a mk2 end put on the mk1 shaft. Or are you meaning the middle mount on a 2 piece shaft?
  8. The floor pans are the same with both mk1/2 auto/Manuel escorts, its just the autos tunnels are bigger for the 1st section, the mounts are the same aswell its just the x member and driveshaft that differ
  9. 80 = way different, 200 is a possibility
  10. I always blocked mine, or you could plumb it into a t fitting into the main fuel line before the pump
  11. Raizer
    lowerin audi
    Think iv got a pair of rear struts still, and have a pair of heavy front springs from a 100 turbo, will have a good look again tomorrow
  12. Raizer
    lowerin audi
    Yeap, just standered struts
  13. I havnt done it personly, but from what iv read/seen/been told the best way is with the mirage parts as in that link
  14. Raizer
    nolathanes
    Possibly me, il suss out a set next time im at bnt
  15. Raizer
    nolathanes
    never heard of them..any good? Yeah man, have a few of them in my subaru aswell, there mint, nice ride etc. My escort camber tops are from them aswell. I think bnt is the main NZ distributer for them.
  16. Raizer
    nolathanes
    I prefer noltech from bnt, i paid around $80 trade for the 1s in my esky
  17. Or you could get your dizzy regraphed(?) so you dont have vac advance at all
  18. Raizer
    audi 100cd 86
    Free up the intake/exhaust, you can get the injectors drilled out a lil bit then after that you will need good $ to get good power. Also if you can get hold of them the 100 turbo (non quatro) brakes and 5 stud hubs bolt straght on (need to fit 4 stud wheel bearings in the front) they are a lot bigger and work well with the factory master cyl. I have done the conversion myself previosly.
  19. Yeah im pretty sure you can get away with certain 13s with the bmw rotors, but id run 14" + with them
  20. Thats a real good idea if your on a budget. Also paying for the head to be crack tested is worth it. Concur! had mine tested before the ports were tidy'd up
  21. Could also use a morrie/austin/worsly etc 1300 engine, or iv seen a austin alglero 1800 fitted in a mini. Also the mg metro front brakes are a good upgrade for minis (if you can find them)
  22. Raizer
    PAINT THREAD
    Yeah the paint we used on the back doors of my van went on all yellowy,a week or 2 later it went to the green it was ment to be
  23. Or if youve got a spare $500-700 get one of palmsides pedal boxs, can even get them with hydro clutch. We got 1 for a mates CA18 esky van, real good quality with AP masters
