Everything posted by tortron
tortron replied to yoeddynz's topic in Project Discussion
https://www.nzta.govt.nz/vehicles/vehicle-types/motorcycles-and-mopeds/information-for-moped-riders/#equipment
But what about non wof moopeds Headlights on if built after 1980. Use hands if no indicators or brake lights
tortron replied to h4nd's topic in Other Projects
Did some more Useful for dialing in the scanner, screen, and printer colur correction. Directly scanned and printed was coming out way too dark for whatever reason (maybe the 1998 scanner) -
Made a brass dome out of an old solex carb float And fitted with a file tapered pin made from a microdrill shank. Nice tight fit. Clock has been ticking away happily the last few days, with no hands, so will see how it goes now. If the hands don't interfere with each other all good, otherwise might need to space the minute hand up with a tiny shim. Then il go about getting it in time, probably paint that brass bit black to match the hands. And that's it, lovely old 8 day kitchen clock back in service, fixed with junk laying around my shed as is my usual turd polishing way
Made a new one From what I can see online, the minute hand is held on by a threaded cap. Mine has a square shaft with no threads, but does have a hole drilled through it (which probably hints as to what year it was made) This is, or was common on clocks, there will be a cupped washer which will press down over the hand, then with some tension on it you poke a rod through the hole and it all holds together
And here's a thumbnail sized ladies automatic for size. Wow so easy to work on something you can see with the naked eye
- 88 replies
I'm confident that this is a piece of low importance, it just has to exist basically, and not impede the pendulum from swinging too much. Some of french clocks use a bit of string there. It needs a good clean, I think that is why it's broken. The mainspring was fully wound up, and there's a scratch in the face and a missing minutes hand. I have a feeling someone tried to gorilla it into working with just a bit more wind... The spring will have broken when it was chucked in a box and knocked around, although did show darkening around the break. Will order a key for it. Had a look on a clock parts site and I can get new hands for a few dollars (postage probably lots as it always is for small stuff), might order a new hanger spring as they are also cheap, now that it looks viable
This is the pendulum hanger spring. It sits right at the top of the pendulum shaft and is more or less just a pivot for it to swing on It turned out to be about a 0.7mm feelergauge
Hows this for a hunny Circa 1940,50,60s smiths Enfield kitchen clock This one has a cast body, I think the movement has a serial I can figure out the date from. Wants some work, it didn't come with a key, but I think I have one. Missing the minute hand, and the pendulum hanger spring is broken. These are available new for not that much, but could probably make one from a feelergauge as the pendulum has heaps of adjustment anyway. Minute hand I should be able to get one, these days you could laser cut one faster probably. Or you can buy a quarts movement with a fake swinging pendulum for about $14
100% do not do this
The Weber swap for an l200 is pretty well received. Lots of discussion on www.mightyram50.com. Lol
Daves new school holden shambles. Oops Rod knock deluxe today.
tortron replied to Muncie's topic in Other Projects
The Holden requirements are that you drop a "water pump lubrication" tablet in the radiator every time you work on the cooling system It's literally one of these https://www.supercheapauto.co.nz/p/rislone-rislone-radiator-stop-leak-tablets-50g-pack/681095.html?srsltid=AfmBOoqQHPLrnGHoq-xadBA4aP4Pkt4V68eGyMm-mLLcJFToGZmEpNCS But with a Holden part number- 754 replies
Didn't realise this book had all the flaps torn out It's not painting the house weather today. Found a yourube video of someone reading the book -
I have that same regulator water/oil trap at approx 1ft from the compressor outlet, then 10m line, then I use a disposable filter (the red ones that screw inline) at the gun. I recently changed to rubber line as my old blue one had gone crunchy and full of holes. Rubber line is nicer. Also got a regulator with gauge to go at the gun (I had one without gauge only on my good gun for clear etc) which is also nice Without the filter at the gun I would get water coming through on more humid auckland days (normally I would aim for a nice day, spray in the morning and if I drained the compressor before hand it wasn't an issue) Compressor runs almost full time spraying a whole car, it puts out just slightly more air than I spray. For home job it's fine I think, no real issue I'd like to run some black pipe up and down my back wall of new shed to make multiple water traps (the reg at 1ft is literally.hust because that's how much extra line I had, it should be further) I do probably more painting than an average shed wombler, but less than someone who paints I guess, and current set up has been fine, with room for improvement
Give her a rev just before you shut her down to clean the plugs out m8- 754 replies
- 6
My mig had the same symptoms Was the wire inside the machine where the earth lead connection is, had comeaway/worn away or something. Was enough to unwind a little and redo
