tortron
Everything posted by tortron
  1. Don't worry, I saw some blank modgies not long ago!
  2. If you go on here and search for blank wheels you get a few options https://www.hyperdrive.co.nz/products/category/228/wheels?searchMethod=2&productType=2&plate=&wheeldiameter=15&wheelwidth=&wheelpcd=BLANK&WheelOffsetMin=&WheelOffsetMax= Fake minilites, jellybean, and tridens
  3. I have a little press tool for reforming busted door lock holes if you want to use it. It remakes the wee ring that's pressed into the steel if it's been busted out
  4. I don't really need it...... lol Basically i want a watch cleaning machine, but not pay watch cleaning machine price considering it's basically what I just described. I see there's a "kiwi cleaner " on the market now that presumably someone in nz has come up with Lo9king at the fancy ones, they have a small.ultrasonic cleaner as well as a heater. Takes the cleaning cycle from 5min to 30 seconds the literature says. I think I'd use a cheap one that fits a mason jar Can buy those little mesh holders on aliexpress, or little tea strainer things that could go in something
  5. I want, what is basically a small mixer, Spinning at about 300 rpm, and changing direction every say 15 seconds I can sit there with a drill I suppose, it only has to run for about 5 minutes at a time, but the reversing is a bit fiddly Maybe something like an electric screwdriver and a timer circuit to switch polarity of the motor It doesn't have to spin much mass, maybe 100g, size of a jam jar sort of thing
  6. @The Bronze gn250 charging system
  7. I have, what is guess is, a coin purse from the 1950s. It's about 2mm too small to put a bank card in, and pull back out easy. So I made one slightly bigger, original has 3 sections, but I made this one 2. Just sealed the edges, will sand them down tomorrow to tidy them up Water lizard skin, with nz lamb interior. Aaaannnd wife has claimed it. So il probably make another just out of leather for me Sewed with my vickers machine. It flew through even the 4 layer bits like it wasn't there.
  8. I believe there was a here's a comfortable job and some walking around money type deal
  9. It's like tracking Elon musks plane. You just track politicians movements and publish them to X
  10. Nope, you have more time and money to spend
  11. tortron
    PAINT THREAD
    I soaked one I forgot about for years with durapox and enamel stuck in it in plain old gunwash, in a hot bath a couple times. Then Let it soak, scrubbed daily, and r4placed th3 gunwash in it every few days Some pipe cleaners delt to the rest. Wasn't that bad tbh
  12. Does it have a miles to km converter installed backwards
  13. It's not legal to do anything other than clean them with soap and water
  14. Can't say that I have bothered. Just drive from rpm mostly
  15. They were made by Tesla did ya know. Presumably thr name was bought out. Modern phones probably have thr same if not better sensors in them now, some of the apps seem quite popular on the YouTube
  16. It's not rated/warranties for it. But it's asphalt with a thinner added to it basically.
  17. Have used blackseal for shitty wood/bike shed roof. Many rusty bits and leaks. Did the job well
  18. One time I also lost one I put in a very special place, and searched the entire garage one item at a time I got a new one When I went to install it, the old one was in the way.... I had checked that too, so I'm obviously a target of gangstalking because it was impossible Anyway This is more like 4.7, so maybe too big? I got it from a local bearing/engineering supplier, they have a range of lengths in different sizes
  19. It doesn't matter how often you check because tards can't be wrangled Honestly, this should pass if it doesn't impede the movement of the pedals. Decking wood meets the requirement for a non slip surface
  20. I looked but they seem for the later bikes? I have a few engines now anyways
  21. I got a dud battery last year Also they said my car was the problem and not charging it. My man, i told you I have a battery tester and the result
  22. Bicycle sprocket m8 Our stove top actually came with a cast iron one stock,but nowhere else I have ever taken my coffee pot has ever had one
  23. Smoke the hemp first, then scrape the shellac out of thr bong
