Everything posted by Nominal
Finally turned in my old DX bottles for some new D-plan ones. Stick on DX said that the scheme was going to end in 2008 so not too bad. Apparently the old acetylene bottles have to go to Aussie for proper disposal.
Keen to see the hill palace -
Your place next month? -
I can do without it this week. -
You can upload them to the form itself.
Approved AND checked? Fancy!
The good one looks amazingly good compared to the not so good ones, seems to have been well looked after.
I guess? On my leaky ones they would only leak vacuum with the pedal depressed. Otherwise no vacuum is admitted to the diaphragm I think? I know the Mercury booster can be damaged if using engine vacuum to work the system before it's bled so watch out for that. /cross fingers and just fit it?
Booster - can you check if it holds vacuum?
K-Trips 1982 Holden Commodore VH Discussion
Nominal replied to KKtrips's topic in Project Discussion
I've still got your old 4cyl if you want to cheat. -
This sort of thing? Help Wanted: Escort MK1 fuel tank outlet (turbosport.co.uk) Maybe a boat place? Or make one up from different bits threaded or brazed together. Or, if this is correct, someone could make you one? Mk1/Mk2 Escort Fuel Tank Large Thread - Page 2 (turbosport.co.uk)
What's the bet again? Gonna come to Wagnats now? -
F&B is handy for me. Not too worried which though as I'll have a car. -
Any details on plans? Keen to catch up. -
The shock mount on the lower arm would probably need some work too.
Probably call? I've only ever bought things in person.
Might be worth a call / visit to Horopito Motors?
Take The Pog route with a TD42
There is always an LD28 floating around.
Make your own? Slippery slope to extreme barrydom @Goat
@_Matt might have some insight into getting things cast in aluminium?
Anyone recognise this rubber mount? Has been used as an exhaust mount but has failed. Easiest option would be to replace, but I'm not sure where from. Mount Shop's website can die in a fire btw.
