Everything posted by RXFORD
I checked my hiace one here and apparantly it is... But yeh cast/forged possibly. I spoke with the bald jesus @cletus himself about about narrowing them that way eons ago and he rekons it was a jailable offense at the time or something like that.
Technically no if it was spotted because you are not allowed to weld castings, which is why I shorten them through the housing tubes. If you remade the flanges from weldable steel however...
Get an initial inspection done and have a chat with repair certifier to undertand the process. He will say what he wants to see and how he would like it done. He will also tell you at what stages he needs to come back for progress inspections, which will depend of the level of repairs needed. And take a shitload of photos throughout. Can give you a more detailed example of the way I go through the process if you want to pm me.
And they think a firearms register is a good idea...
Advice required: Making complicated brake duct out of aluminium sheet
RXFORD replied to Hyperblade's topic in Tech Talk
Might help to make a wireframe buck/template first. Can do it with tig wire or gas welding 'panel' wire. Bend the wire to the shape you want, tape/tack weld them togethor, then you can lay paper over in sections to transfer onto Ali sheet. -
Runamucks - VG Valiant Sedan of Lawn Ornament & Rust
RXFORD replied to CUL8R's topic in Project Discussion
Re: 620 diff. Do you recall what that 3.9 you scored came from? Thats a pretty rare find. If it was same axle spline then must have been from an old Silvia as the Fairlady Roadster and 1600 Wagons have smaller spines. If you come across another, let me know, I need one for my pickup. -
Probably Takanini PickaPart. Theres a rack of them, then a shitload just scattered in the ground. Zebras selection was ok, but I havn't been back there since they reopened recently.
Is an Gtr style intercooler an option? Shorter but quite wide. Instead of having the outlets of the end of the tanks, have them exit back toward engine. Or just run a smaller one so you don't have to change piping but have a water/meth setup as backup?
You need at least 0.5° operating angle on a UJ. Lesser the front shaft angle difference the better but not less than 0.5°. Currently you are at 0°. And max 3-3.5° operating angle on front UJ out of box. Now if you raise the hanger bearing so front UJ operating angle is 0.5-1° (front shaft initial angle of ~4° down) it will lessen the centre and rear UJ angles and still be within the max 3° front UJ angle. Centre and rear UJ's still have pretty bad angles but not much can be done about that without a fair bit of rework. If you set the pinion to ~6° down (flange pointing up) it will compensate for a degree or so of bushing flex under acceleration and get you close enough to where it should be happy. Link design/geometry will play a big part in driveline performance too, but thats confusion for another day.
If the oiling system allowed it, and if I was chasing driveline perfection I would be setting the engine to as flat as possible and remaking the manifold/tunnel etc to suit. Just depends how much work you want to do I guess.
Because you have a greater angle on the gearbox than the first shaft, raising the hanger will make the operating angle of the front UJ worse and its already at 3.5° based on the angles you mentioned on box and first shaft, so wouldn't really want to go any more than that. The lower the first shaft angle, the less rotational pulsation the second shaft will have to try cancel out. The higher the rpm, the lower the operating angle should be. If it was the other way around like most vehicles, for example the gearbox was 3° down and the first shaft was 6.5° down, then raising the hanger would help get the front UJ to a lesser angle. Are you sure the box is 6.5° with carb where it needs to be? Are you measuring that off the crank pulley/sump? Seems like alot. I can't remember what the last rotary I mounted ended up being with the carb level tbh. Post up a rough/close enough angle of the rear shaft when you get a chance. I'l calc it how it currently sits and see what the pinion ends up at.
Is that laid out or at ride height?
What angle is the 2nd shaft on?
Most of the online diagrams go out the window with bagged stuff because they are geared toward the pinion being far lower than the output shaft on trans. Spicer has a good angle calc.
Go take a marketplace Hilux for a test drive and switch them out. Thats what Billy T would do.
The qd32 is just a newer big brother to the td27. Bellhousing patterns are the same and a bunch of other parts like the manifolds are interchangeable so its possible the heads are the same or similar. The 'Td27 Torque' facebook page is a wealth of knowledge so chuck up a post on there.
The only real 'controlled' way to shrink is oxy/acet heat shrinking. You were kinda on the right track, but most likely heat up too big of an area with the butane. Firstly find a dolly thats either the same crown or slightly less of a crown as the panel/area you are shrinking and grab a flat faced panel hammer. Onve you have identified the area thats too full and needs shrinking, use a small gas welding tip (not a big cutting tip) and heat up a small 5c coin sized spot til cherry red, then while its still red, start lightly hammering it. I set myself up something I can safely chuck the torch over so I can drop it and start hammering. The initial blows might have to be a bit harder to dress the swollen centre down, but then for the next 20 seconds or so, just lightly dress the surrounding 50mm radiused area down. It should now be cool enough to touch. It will still be warm, but nothing crazy. The light hammering just helps control the shrinking while cooling in that area. It may shrink slightly more once its completely cooled depending on the location, but at least it won't do any weird shit because you kept it localised and told it what to do. The idea behind the lower crown dolly and flat hammer, is to dress the material into itself, rather than stretch which is what would happen with a higher crowned hammer and dolly. The concentrated pinch would just start stretching again. Don't use any form of wet rag or air to cool it. Just the hammer/dolly, then let the rest cool naturally. Shrinking discs work ok sometimes but it has to the 'perfect' high spot. Once you get good at heat shrinking you'll be set.
Hah, good timing, you peeking through my window!
1 degree is 60 minutes, so half a degree = .30, not .50. Your left rear camber final is 2.38 (2 degrees 38 minutes), which is just over 2.5 degrees, (only 8 minutes over) I'd just run it through as is. The rest is fine and as its close enough that if it were checked again on a machine it could be within.
Holy moly this thing was chooched, but you're getting that shit handled !!! Solid effort.
Actually, I looked at pics again, is that Andrews B1600? Doesn't look clean enough to be Wiremu's. Either way TDS did both of them originally but I'm pretty sure the B2K truck isn't and never will be legal without alot of rework. Andrews truck is legal though but was certed wayyyy back in the day. I think if he recerts it for the engine conversion those arms might get picked up and fail because of welding.
Regarding the pie-cutting issue... that looks like Wiremu's B1600 which Mat at The Drop Shop originally bagged. He always did upper arms like that and back when I worked there they used to pass cert, but theu won't these days because of the welding. Nowadays and for the past 10 years at least, modified suspension arms need to be Tig welded, not Mig'd. I think you will have a hard time getting a yes or no from Clint or any certifier over pictures like that because of how little they deal with that kind of mod these days. But the general idea is whats required. If it were me, I would just do whats needed, like open up the centres for bag clearance like in your pics, pie-cut them just enough to your desired tyre size (+5-10mm incase of uneven ground) do all the necessary reinforcement, then when you are closer to the point of getting it legal, submit pics/ measurements/Ndt report etc to Lvvta for Design Approval. That way you can continue with the rest of bag/shock mounting etc. If they are a complete fail at Design Approval time, then the only option will be fabricated tube arms, which isn't really too big of a job amyway.
On pre frontal impact utes you can remove the rear tubs as long as you have a hardlid, and can remove front tubs as long as it has a bonnet. Wheel tubs are not classed as structural on a pre-frontal full chassis vehicle unless there has been a rule change recently I'm not aware of. However, some certifiers may want to see a larger/higher tub put back in, or some form of reinforcement. Only a small percentage of minitrucks in Nz have had new front tubs fitted after bagging. Most people just leave it open.
