Everything posted by sleeektoy
Sleeektoy's 1974 Toyota Celica Liftback [SLEEEK]
sleeektoy replied to sleeektoy's topic in Projects and Build Ups
So... a change in the place i took this for a WOF meant it had a bit more of a thorough inspection. It didn't fail but he mentioned that some rust in the passengers floor would need attention soon. So some investigation happened. Turned out that hiding under the sound deadening was a little more serious than anticipated. Likely a leaking windscreen caused this. Out with the cutting disc and I had at it! And then glued it all back together Grind, Sand, and Prime - phone was left in the house so no pics except after And finally a renewal of paint and anti-chip coating. A nice tidy up for it.- 13 replies
- 25
+1 for steel cuts on odd size items
The French race them and you can get a big bore cylinder/piston and hi comp head - good for a lot more torque and top speed. The pedal gear ratio is a bit crap and takes a lot of work to pedal without the engine so i fully understand the sweaty mess situation. With the engine running it is fantastic for 30+Km/hr and still being able to pedal (albeit rapidly)
Tried my hand at painting some pin striping - not a bad 1st effort. I replicated all the factory stripes it originally had
I'm stoked at how good the tank turned out. I painted it last week and finished it over the weekend.
Hung the painting out to dry... glossy goodness. and a couple of bits needed a bit more fettling too
Some pics of the wheels i restored. Rims and spokes were too far rusted to save. New rims, and spokes, and whitewalls. Plus cleanup and re-chrome of the German " Torpedo" single speed, back-pedal brake hub.
I had also reconditioned a whole pile of other bits. i unearthed all those today too.. Moteur all done - big-bore 50cc piston, honed barrel, new headlight and plastic side cover. Front mudguard and engine mount plates painted and everything plated. Including fuel tank that took way too many hours splitting it apart, panel-beating it, sealing it back up. still to be painted. before.. after.. Exhaust - gutted out and tidied up Brake calipers zinc plated and reassembled. New tail light and re-plated/refurbished bulb holder Tread plate cleaned up new mudflap + re-plated support handle bars re-chromed and everything cleaned + re-assembled. also new bell The auxiliary power units were re-chromed, nos pedals, and rebuilt main bearing and lastly - re-plated bolts throughout
Well... this got put under the bench and forgotten about for 3 years updated pics back - some pics are lost unfortunately. Its back out on top of the bench and the bits are being worked on. Some primed bits some of the pitting I have been dealing with .. which I'm priming, then skim filling and sanding it, then high fill priming after
Do they have any affiliations with MTA(Motor trade association) or similar at the workshop? Could have a yarn to them about it if they are. Also LTNZ are getting pretty strict on the WOF workshops now - if you feel it shouldn't have passed due to the work not being done, then formal complaint to them and they will investigate. FYI - Wheel bearings can sometimes be adjusted with the wheels on the car - if you can pop the outer grease cap off, you can pull the split pin and pull out the outer bearing to jam in some grease. Then bung it back together adjust the nut till tight etc. Depends on the type of wheels and centre caps. (I would however not recommend this be done .. ever) Also - drum brakes need exactly the treatment @Yowzer mentioned to properly get them working. If nothing needs changing, then it would probably take the same amount of time to try and clean it from the back as it would to remove the drum and give it a decent check/clean and proper adjustment
No to put a downer on the plate idea - but It will have to go on the tow vehicle, not on the caravan. Max of 5 characters on a caravan personalised plate
A long overdue update on this car. Re-added the pictures due to photo-fukkit fail I picked the car up from the panel beaters in late 2015. It was unable to be finished due to the ill health of Murray the panel beater. Amazing work done, just need to get my ass into gear and get it finished and painted. Not a lot has happened to it since as i have been busy working on the Racer, building the garage, engines and other things. It is still being worked on at a very slow rate. and it is keeping good company in the shed. Smaller bits like the carbs and airbox for the engine have been done and are sitting in the cupboard ready for refit.
- 4 replies
- 19
“It seems to me that the natural world is the greatest source of excitement; the greatest source of visual beauty, the greatest source of intellectual interest. It is the greatest source of so much in life that makes life worth living.” David Attenborough Here we have an omniscience of oldschool GC's gathered in nature to observe oil burning jalopies
Same result here. Prepped a surface rusted inner splash guard both sides as per their instructions. POR15 coats with the under and top coat and fitted it to the car. 2 years later i pulled the splash guard as orange streaks were running out of it. Completely rooted flaking rust underneath and the POR15 was all that was holding it together - peeled it off to find swiss cheese steel under it all.
Wifes away ... i shall randomly turn up and make a burger disappear
Sleeektoy's 1977 Racer Celica RA28 (WTF another one!!)
Getting more confident at this metal foldy bendy stuff.. Centre console bracket was missing from this car so i copied the one from my other celica. Carpet all installed Back seat area all cleaned/painted Wheel arch vinyl was tired so i resprayed it And finally stopped procrastination and primed the drivers side roof- 51 replies
Small update: Floors cleaned and painted, Dash back in, and rewired some horrors behind it. Marine boat carpet is being cut/fitted as I go - Blue to match the seats. Roof still isn't finished yet - gotta get motivation and less distraction from other jobs. I could possibly turn the key and make it go with a charged battery and some fuses- 51 replies
Do the steering boxes have a coupling like this? Like most 70's toyotas with steering boxes have... That would therefore mean the power steer box may work?
The Drivers side roof drip rail was a little bubbly so this was also investigated for rust. BOY oh BOY did I open a can of worms. The drip rail and outer roof has 3/4 been replaced Now for more paint/sand/paint/sand....- 51 replies
- 21
- 51 replies
Wasn't really happy with the paint and I cut through in one spot so the decision was made to repaint and clear coat it. Also repainted the dash top and cage given the easy access with the windscreen out- 51 replies
And lift-up reverse gear lockout is standard on the T40/50 of this type
