Toucan
Moderators
Everything posted by Toucan
  1. Yea go Josh!!! Bringing another bad boy back to life
  2. Yea I have no idea what uses the ball end :S My 1300 cable worked fine on my weber, only problem was where to mount the bracket so that the socket would line up
  3. Toucan
    FORD 1600
    A pre-cross flow has both the intake manifold and the exhaust manifold coming out of the same side of the head. A cross flow has the intake ports on one side and the exhaust ones on the opposite side, so they are quite easy to tell apart. I'd also look at the option of putting a 2L pinto in, they are the sohc 2l that come in lots of cortinas and the higher spec escorts, it would be a bit more work to put in but probably worth it,. But if you want a simple swap then yes a 1600 cross flow will be piece of cake, and 711M is the number cast onto the side of the 1600 block's I think.
  4. Keep it inside, get all new parts so its all clean an shiney, lay them all out on the kitchen table, fast an furious styles
  5. Yea I'd have to agree 5grand sounds steep for what it is
  6. Yea my mtes 2tg sounds awesome with the twin sideys, I'd go with that.
  7. Toucan
    Reverse Gear
    Yea I'm going to soon as exams are over, such an inconvienience
  8. Toucan
    Reverse Gear
    Well no shit, It's THAT hard that I could swear somebody has welded a forcefield around my reverse, It can go in, but its gear stick snapping stuff I tell you so I'm not all that keen on doing it. Any other ideas???
  9. Toucan
    Reverse Gear
    Cause it's not just "not going into gear", it physically isn't able to be moved into the position. Grrr need it to stop raining so I can have a look, so puzzling dammit.
  10. Toucan
    Reverse Gear
    I have a mint g/box, semi worn clutch, awesome engine. Yesterday: Car works 100% fine. Today: it's like reverse is seized, no amount of clutch or revs would get it into gear, in then end I used brute strenght and it went into place and then worked fine, no funny noises or what have you. Then I'm done with my reversing and go to select first but I'll be dammed it doesn't want to come out of reverse, so I force it out and away I go, all the other gears are fine and can be selected normally, there were no weird noises or anything leading up to this, just literally happened overnight. Could my gearbox have fucked itself overnight? or is it likely to be something like a worn clutch? It's raining so I can't go have a fiddle at this point in time.
  11. Like lowlancer said, its perfect. Can you arrange some interrior/engine pics, chur
  12. KhroMies the engine bay
  13. Thats what I was thinking
  14. Wouldn't be that hard, just Atropine's lame ass mechanic sux, no offence
  15. Toucan
    quick steer rack
    Ohhhh geeeesus... havent had such a good laugh in I don't know how long
  16. 2l zetec??? I reckon dohc engines in a rearwheel drive layout finish off an enginebay really nicely, specially if you have shiney cam gears nd no cambelt cover
  17. Toucan
    The Shock Poll
    I got monroes... cause the front had them already and some second hand rears appeared on trademe at the right time in my life
  18. If the car was originally an auto, it will fit as the autos have a bigger trans tunnel, if it was a manual, then you will need to cut the trans tunnel a bit bigger, look around in past threads, this has been covered about a 100 times now
  19. You really think they would check engine codes and such???
  20. Pictures or it didnt happen
  21. Just get them to join up to oldschool, and when there is enough demand, ask admin if they can spilt the forum into toyota/mitsi/escort etc
  22. I'm usuing standard repco one still, but I have my "custom" way of mounting it so next time round I can stick any brand of filter in there without too much trouble
  23. Get a Neo engine out of an R34
  24. Wicked idea, then you could go rallying with two passengers aswel as the co-driver haha
  25. Thats what I said, either didnt use one or left the original on there
