Posts posted by WankBankA100
Yeeeeeah boi! @Truenotch, this what you were on about?
2 minutes ago, Chunky_t said:
@WankBankA100 are you riding your cb100 this year?
Na, I actually built it for a mate to ride (and to test out small 4 stroke life), and then tried to palm it off to a few people so they could make it, but no interest. So I stopped racing to get it ready in time. It's in final assembly stage, just waiting on some fork gators, and now some handlebar controls cause the other ones I ordered didn't have the right wiring setup for the wiring loom.
So still A100 life this year! -
On a side note, $5 per meter fuel hose from Trademe that has Chinese writing on it... not very good.
52 minutes ago, Duke Blackwood said:
You have a good memory. It’s not a fond memory for me - stopping every 30kms to top up my oil with a syringe which I kept in my breast pocket; resulting in well oiled nipples.
Not this time. Behold.
I remember you swearing you’d bring a bigger bike next time! Haha
4 hours ago, Duke Blackwood said:
Im pretty sure I have the “who’s got the least appropriate tyres” competition cornered.
Probably an honourable mention in the “least luggage capacity” category aswell.
I’m also hoping to podium in “most cigars eaten” and the coveted “best moustache”
@Duke Blackwood
Please say you've increased 2 stroke oil capacity?- 1
I think the A100 runs the same sprockets as a TS100. Got a surplus to requirements 13 tooth you can play with?
whats the motor in that? Tf 125
31 minutes ago, anglia4 said:
I've finally finished putting my bike together and started putting some miles on it.
Rode to work today, topped out 85km/h on the flat haha Poor thing really struggles to get into the power band in top gear.
I'm pretty temped to gear it down a bit to get it into a sweeter rev range for open road thrashing.
@anglia4 What are you operating bike wise? -
10 hours ago, Beaver said:
No, because @Geophy is a bitch and isn't going.
I can grab them from you? Best bet is actually @WankBankA100 as I'm touch and go as I'm not guaranteed to make the start line, but happy to grab them anyway as Ill be seeing Richard before then.
I’ll grab em off you when we sort your bike out...
I mean, incest isn't bad unless you make children right?
29 minutes ago, rumrum said:
riding someone else's bike is like fucking your sister......
hahaha
How hot is this hypothetical sister?- 1
Question time, I'm planning on bringing my Honda CB100 (Adventure spec) along as a backup bike. Will there be space on a trailer for it? I may be sweet talked into letting someone ride it if their bike breaks down........
Jason was gonna ride it, but he's out. She's running all new gear including a fully rebuilt motor.- 1
We have a drop-out. Jason H is a no go due to work commitments that weekend...
Deleted cause I found my answer on MopedNZ...
2 hours ago, MopedNZ said:
Phwoar. The Ubco fellas donated me some tyres so I’ll be throwing the far one on the front of the wave instead of a Shinko.
Swapping them over this weekend in prep for Raglan ride!
All the perks! Gizz us the specs? -
@00quattro00
Anaconda's pricing...1. Head stem bearings (preferably tapered type, aftermarket is fine) $57
2. ATC110 Piston & rings Please confirm pin diameter & piston bore size) 15mm 52mm $120 That is a bigger bore than the CB100
3. Front & Rear brake shoes PN 45120-001-010 $19 per wheel4. Timing/Cam chain PN 14401-107-000 $295. Points PN 30202-107-004 $256. Head Gasket PN 12251-107-760 $22
7. Front wheel bearings & seals PN 96140-63010 (2 of) $11 ea & PN 91251-030-000 $128. Rear wheel bearings & seals PN 91257-230-000, $12 PN 96140-62020 $9 & PN 96140-63020 $13.50
9. Front fork seals & Circlip PN 90756-028-000 $12 & PN 51447-028-000 $7- 1
1 minute ago, 00quattro00 said:
Its an atc125, 15mm pin
Ah yip yip, I'm gonna run a XL125 crank/rod, so can run an ATC110 piston. Apparently higher compression than the standard plus 7cc extra. Man the power gaaaains! -
2 minutes ago, 00quattro00 said:
I just started this weekend on my ct
9050, hopefully can get all the bits in time
Hit up Anaconda Honda in Te Aroha. I'm looking at $370 for piston & rings, head gasket, head stem bearings, all wheel bearings and seals, timing chain, and a couple of other bits, which I think is pretty well priced. Can't remember the full list now.
What piston pin size does the CT90 run? -
1 minute ago, Truenotch said:
Yeeeers
I'll need to get my mits on some CB50 stickers actually................- 1
19 hours ago, 00quattro00 said:
No,
I need all the time to get my engine built
Yeah, I'm in same boat on a CB100, but I'm doing ground up rebuild at the mo. Just started! Also will need to do re-vin process.
3 hours ago, Beaver said:
but I can't pass up a chance to stir the pot.
How dare you beaver... Next time we see each other, scraps are on, for a second or two, until I revert back to my natural teddy-bearish state.
Molesworth Moped Melee, 5th, 6th. 7th march 2021
in South Island Region
I’m so in! I’ll defo CB100 this ride...
