Everything posted by shizzl
Quoted that j1403 at a few different places, this is what they said is the hose. she’s some thick walled shiz
Thanks mate. I’ll quote that and hope I don’t get asked for a rego
Oh god , into the rabbit hole of updates and nonsense we go, see ya nek week
Yeah for booster. 10mm will work fine. 3/8” is toight I’ll try them , cheers @Bling
Where can 3/8” vacuum hose be sourced? typical culprits don’t have anything in stock
Sunday 16 April= Auckland cruise and BBQ
shizzl replied to cletus's topic in Upper North Island Region
Highly keen for this -
Official Mitsi weirdo buys another weird Mitsubishi
shizzl replied to fuel's topic in Other Projects
How stinky was it when you got to her? the water that drained out smelled like a 6 day old nappy, I was hoping the drain plugs and lifting the carpet let it breathe enough until you got to it. carpets look awesome -
Go all the way and run triple IDA’s on a ez30, 6 trumpets out the bonnet on a custom manifold.. haha just to be different
Absolutely not happening haha I had flares on a s1 rx7 I bought, never liked them, I’ll leave them for the spitfire rollers these are 8s so a whole inch wider than OG RX3UTE, I will give the arches a gentle roll with my guard roller. tyres will be some used semi slicks for now
So still haven’t finished body work. I put a hold on it until the hunter is legal. but I did make one purchase that was very necessary… let the photo do the talking Your welcome
- 47 replies
- 35
Cough #porsche 911 turbski with a late model 6speed box
Yeah, don’t even think he’s used it. Just changed things round.
- 133 replies
- 15
I can’t wait to get these reactors retrimmed to a more suitable colour. I made up a switch panel today just to temporarily *permanent* house the switches. have a kill switch, diagnostic switch and the red one has been set up to be the engine check light. also made up the centre console plate and painted it. Need to get some black vinyl to finish it off. Then the screws will disappear. also made a bellhousing plate to fill in below the engine. running a golf ball for a gear knob for now
- 133 replies
I saw a group racing these at Crank up in Edendale a few years ago. they were part of a club possibly out of Gore. most of their rigs were modified reel mowers, was crack up
Did a thing and drove it home today. off for an alignment tomorrow, drives straight as already. definitely need to address the exhaust height, it’s low, too damn low now that I dropped it another 10mm or so.
- 133 replies
- 22
I never ran a tsl on my truck carting my Stockcar. the system is a joke and needs fixing. imho a tsl should only be required by those who offer transport for hire or reward. Ie paid cartage of goods or passengers. I once bought a 510 trader off temuka transport to carry my first Stockcar, he told me to leave his tsl on it and run it as is. What a gc.
Well boys!! It drives, and boy does it drive. handles great, smooth acceleration. so stoked. no driving vid, no co-pilots available. made up 50mm blocks from 50x50x5 shs. booked in for an alignment on Thursday. just need a cert now
- 133 replies
- 25
Wow howdy, Humpty is all together again. fitted a air filter off a pipe due to not many other options. radiator was modified by Waiuku mufflers and worked perfectly. there’s only a couple of things to do to button this up now: hose clamps on the intake elbow. fit the o2 sensor. replace the rear UJ that I have. swap the 40mm blocks for 50mm blocks. make a centre console cover plate to suit the shifter. give it a wash and an alignment.
- 133 replies
- 19
Throttle control haha. it’s not a daily, so I’m not too worried about a lumpy cold idle. aslong as it runs and drives for now
Update. seems to be sorted. took the throttle body off. found that the IAC was open venting into the intake. Removed it and made a blanking plate. gave it all a good clean out. got it back on , fired up and died. adjust idle stop. then fine tuned the idle with the screw. cheers legends
Legend, I’ll try this too. thanks
Just got home from car club night, they said something similar. Sounds like they have wax or something inside the throttle body to help control cold idle etc. can block it off and manually set idle, clean it out etc. coolant system is clean as. but will throw it outside tomorrow and let it get to temp and see if it changes anything
Hey all. need some further ideas to my issue. 4age fires up really nice, idles away at 2000rpm cold, then after a minute it starts hunting between 2-2500rpm. I’ve done the old brakeclean test around the manifold etc. this is running a map sensor. possible timing issue?
Nice, that’s exactly what I need to sort. looks clean
