Everything posted by JustHarry
@RUNAMUCK +1 for comac. We use them at work. Almost always have what we need. No human interaction is a bonus
Got the tacho looking hot. However not working so hot. I dont think its reading accurately. But i also have no way of checking that so maybe im imagining it
- 50 replies
Nelson Area meets. Next meet TBC
JustHarry replied to sidewaysickness's topic in South Island Region
Oof yes. Definitely 4wd haha. Its quite manageable in 4L most if it is pretty cruisy but some of it requires carefull wheel placement -
JustHarry replied to yoeddynz's topic in Project Discussion
Fold out kick starter? -
- 50 replies
Got the patch in welded and seam sealed up. Shouldn't leak water into the cabin now. Most of it is covered so just flicked a bit of black on it for now
- 50 replies
- 16
- 50 replies
Also a strategic dent in the dump pipe will make little to no difference to the engine
The ceramic tips the guns usually come with are pretty shit and the hole opens up pretty quick with use. When this happens the venturie effect is reduced and it doesnt pick much sand up. There is two options. Replace the tip regularly when it wears. Which most people do Or there is a company in chch that specializes is sandblasters and sells some fancy tips that cost like 250$ and last "forever" (we go one for the bast cabinet at work like 3 years ago. We were replacing them every couple days and since havnt replaced the fandagle flash one. Cant rememebr where we got it from but can find out) Work has a machineryhouse one thats pretty decent otherwise.
I have the number for getting tools replaced on my toolbox as i suffer the same ussue of no truck anymore. Will get it for you minday
Mr.mk1's Mopar or No Car '70 Dodge Coronet
JustHarry replied to RUNAMUCK's topic in Project Discussion
Mig welding a bonnet like that is a sure fire way to fuck it. Also rust converters are a have. The correct way to deal with the frame being rusty like yours is to get it sandblasted. Its inexpensive and does the job properly. -
Whats it weigh? Wouldn't be very heavvy. If its an issue just put an unbraked coupling on it?
I know right
Still on the look out for a 3.36 holden diff for this. Ht/hk/hg Should be corse spline but will pull an axle and check
Sounds like a bit of a have Usually trailer brakes are just sorta like yeah they arnt dragging and they stop a free wheeling wheel so the do something Good to go
When it rains my feet get wet There is also a cold breez from under the dash whilst driving I thought u would investigate. So i pulled the dash out found some yucky Then this happend Then this happend Not ideal But a pretty good result considering its a 70s toyota. Will be a straight forward repair
- 50 replies
- 18
Can stay with me for a bit if its only a week or two. Can keep my l300 company If the seller can deliver to chch makes it easy
Did this this morning at work. Centre bearing was noisy and loose. Hilux centre with the crown housing bolted around it. Sorted Much quieter
- 50 replies
