Mof
Everything posted by Mof
  1. What do you mean it spins fine? Can you fully rotate the driveshaft by hand with the gearbox in neutral?
  2. Can you swap the two gauges and rule out it's not a funky gauge?
  3. Is molesworth no good?
  4. This And change the oil
  5. Mof
    Trailer axels.
    I've seen them in all sorts of positions including at the bottom, mainly to clear the chassis. I have a bit of flat bar same thickness as rotor. Take off caliper and fit flat bar between pads, hold caliper so screw is at the top, and bleed.
  6. It must dry up or something too because sometimes it's like a dark brown scale, like little bits of tree bark
  7. I've had bug block pickups and banjo fittings, same symptoms.
  8. Recommend these guys if you need a tank/tanks https://www.kiwitanks.co.nz/caravan-water-tanks And these guys for bits and pieces https://www.rvworldstore.co.nz/
  9. Stops the battery moving because the clamp hasn't been put back on
  10. 3M double sided foam tape. Definitely not Scotch
  11. There's no such thing as 6.30 on a Sunday
  12. Run big cable directly to starter, then smaller cable to fuse box/alt etc
  13. Is it ok with the top 10 people? It's pretty cramped in that place. I see there's a park directly across the road
  14. Hopefully it doesn't bucket down again
  15. Nelson Top 10 is 55 a site yeowch Tahuna 23+ Maitai valley 10, I think I'm going there
  16. Rarangi and whites bay are both a little closer to Bridges than onamalutu...
