Everything posted by Mof
What do you mean it spins fine? Can you fully rotate the driveshaft by hand with the gearbox in neutral?
Can you swap the two gauges and rule out it's not a funky gauge?
Is molesworth no good?
That, and change the oil
This And change the oil
I've seen them in all sorts of positions including at the bottom, mainly to clear the chassis. I have a bit of flat bar same thickness as rotor. Take off caliper and fit flat bar between pads, hold caliper so screw is at the top, and bleed.
It must dry up or something too because sometimes it's like a dark brown scale, like little bits of tree bark
I've had bug block pickups and banjo fittings, same symptoms.
Suzuki 4wd? 5x5.5 139.7
Recommend these guys if you need a tank/tanks https://www.kiwitanks.co.nz/caravan-water-tanks And these guys for bits and pieces https://www.rvworldstore.co.nz/
1kz's like the cca's
Stops the battery moving because the clamp hasn't been put back on
3M double sided foam tape. Definitely not Scotch
- 340 replies
Run big cable directly to starter, then smaller cable to fuse box/alt etc
