Everything posted by Mof
Battery is in. What do you do when the cables are getting too close to the lid? Put them under the clamps Cables run Power
Engine bay plumbed and wired Didn't do too bad a job trying to hide everything, except for that throttle cable grrr
I think it dries and flakes in the tank, then blocks the fittings. Is it kind of a pine bark ish texture? I'd definitely be checking the fittings and pickup with that shit around
Check water trap in bottom of filter
Fuel blockage, usually collects at joins, banjo bolts/fittings. Take pipe off at filter and check. Could also be at pickup, but hard to check that, could blow down the line back to tank. (Don't forget to re-prime after) Actually, check the banjo at the pump first, fuel line from filter to pump. They usually have a filter in it.
Mof replied to h4nd's topic in Other Projects
OMS did mention gussets between lower and upper horizontals. No, you're not. -
Mitred corners Mmm yes -
Problem with putting a trailer under it is if you go through a culvert the drawbar might whack the rack. And depending how high, might not be able to lower the tailgate -
Strap bikes to huge front bar? -
Engine's painted, stuck on gearbox, and back in the hole Then I got distracted by snakes Will fix this certified fuckup tomorrow too.
Does it currently get hot/poke coolant out of the overflow?
Helluva night
Can-o-worms
Front subframe and suspension in. Brake master in, and brake pipes made up and new brake hoses. I have no idea how the routing of the oem brake pipes were, the ones that were in here were an absolute abortion and could not stay. I think I'm happy with how I got these to go. Gearbag painted. Engine next. How many days to Nats?
I actually had to double-take First photo I thought the star was hanging from the shed wall
Holy good god that pipe is fuckin LOL!
Green and black, so much better than green and blue and yellow Oh yeah, the underside is green And I see now that I missed some goddamn blue!
Green Not the right shade of green unfortunately. It was a bit light, so I put a dab of black in it which has come out looking kind of British racing green. I really like this shade. The paint out of the can was John Deere and not the right shade anyway. I might redo it tomorrow without the black and see.
- 42 replies
Did you ruin your way to work this morning? This rain should make your ride home awesome
