Everything posted by Mof
Molesworth Moped Melee, 5th, 6th. 7th march 2021
Mof replied to RUNAMUCK's topic in South Island Region
Just got home Cruiser packed a sad just coming in to chch, managed to limp it to work, borrowed ute, left trailer and Aaron's bike there too, dropped off Aaron Big day -
- 609 replies
Currently looking like a bit of rain for Sunday, that could change between then and now though. -
So I'm easy for Thursday night/ Friday morning Does anyone need bike transport from chch, back to chch? -
The one I put in my Samurai was on 92 off 82 and it was spot on Hope that helps
Oh that suuucks -
Yeah no problem Benchtop mounted? -
Oh I thought the vertical spring was 'lifting' the handle, and when removed the weight of the handle was too much for the hiace box to centre. As you were
So you removed the spring from the Thames shifter and the lever is too heavy for the gearbox to pull it to the 3-4 position, is that what you're saying? I got a bit lost. Does the Thames lever drop without the spring? Can you just shorten the length of the thames spring until the lever rests in the 3-4 position?
I can assist with this -
^ I also I got no problem carrying bags, gear etc, if you're packing light. No room for kitchen sinks -
Overdue update End cupboards painted an in Floor down, fridge in, end panel on the kitchen unit I didn't get a very good picture of Kitchen light, and polyurethane the benchtop I have to redo the bathroom because the fuckin glue let go of the vinyl
What's the Friday start time? -
I'm not worried I'll be half a km back just cruising picking up the scooter pieces as they fall off. That slip looks good fun to negotiate, doc'll probably shut it to poop parties -
Did you go off pulley mark's, or make your own Mark's?
Don't even worry about it What's this now? Vehicle access problem, or too gnarly? -
Yeah it is. Apart from the pole that I welded up the holes and chucked some shit primer on it
Ok if one wanted to paint the steel framing in here that's going to be exposed and a feature if you will, what sort of paint would one use? Something of the satin variety
What about a short shroud/ scoop at the front of the exit to create a venturi of the air passing under the vehicle drawing air out through the rad
How about Skip
Can you/ have you got a scoop under the back corner of the cab? Also are you using the engines water pump or an electric one?
UNC is coarse? The end of the stud doesn't look so good
