Everything posted by h4nd
options for creating a USB flash drive, that would burn half a laptop down. http://kukuruku.co/hub/diy/usb-killer
It's a good idea, can we re schedule? next munf?
Quite tempted, will have a better idea of my obligations in a few days. Food run? Could make it a gourmet tour.
Thermal expansion in a connector etc miiiiight cause the symptoms, but the suggestions above are a good bet.
Got a pic of where things are earthed? Are the guages / stereo sharing any wires?
Laser ignition improves efficiency. http://www.thetruthaboutcars.com/2015/02/princeton-optronics-laser-ignition-boost-ices-efficiency-27/#more-1008890 I wonder what engine was igniting 27% badly.
Yeah thanks for that Ky. I would'a been up for a big wait from Japan again, if the blardy things are even available. Kicker: Not sure about the piston clearances, but it's all as stock as a Maggi soup sachet, give or take an oversize (1mm from memory). Jennings book is excellent. I've been through a couple of books lately, and mostly they're generalised waffle. Jennings is however a recipe: for power X, you need -revs Y, -compression Z, -port timing A, etc etc http://www.amrca.com/tech/tuners.pdf
Right. The chrome (top) ring failed, but the locating pin was still there. Builder said he'd done the usual exhaust port radius, about 0.2 - 0.3mm. At his workshop, I showed him an original bore jetski motor with ~0.7 - 0.8mm chamfer at 45 degrees. Then I sent him an excerpt from Gordon Jennings excellent "Two stroke tuners handbook" Yeah, 0.4mm minimum recommended, and 2mm high on the 10 degree chamfer, which is a large change in port timing. No wonder it was down on power. I happened to have a appropriate sized piston in my stash, which measured up OK (not barrel shaped), was crack tested and fitted. He's re-shaped the ports, rebuilt it, and apart from a minor issue of a top mount / water feed cracking (replaced), it's running again. It's much crisper, and pulls through 60mph much better. Best yet, he's standing by his work, and not charging for this work. Kudos. It's been a blast tootling around in it, and true to 2T form, my hands have been grimy 4 times in the first day having it back.
There's Dai's for sale in Aucks....
Tell me stories about Skope, what I missed. Anybody got a few good pics?
You efi guys, I'm curious, does fuel temp affect your mix much?
d = 1.38m, so 110kN @1.38m/2 = 40kNm 110kph = 30.5m/s, so 30.5 / (3.14 * 1.38) = 7rps, so 60 x 7 = 420 rpm... Power (kW) = Torque (N.m) x Speed (RPM) / 9548.8 P = 40kNm x 420 / 9548 = 1700kW ~= 2300hp Still sounds a bit high, the really big Chinese / American steamers topped out at 3000hp 6000hp, I think. Edit: There's the problem, that initial assumption. 7MW curves: http://en.wikipedia.org/wiki/Tractive_force
But that's just converting to distance, and back again via ω? Work = F x d, and P = F x v but 110kN x 30.5m/s ~3MW, 4000hp, which sounds too high. I was expecting 500-1000hp.
Saw the old Ja steam trains in Dunners. Tractive force blah blah blah 110kN 110kph. So is the conversion to hp force x distance x speed? Or is the assumption of max force at max speed not legit?
ajg193's Heap of 1983 rust (KP61 no. 2) - Beat on the panels
h4nd replied to ajg193's topic in Project Discussion
Morrie side valve. They have such a lovely tone on song. Kidding, (somewhat). I hear the Mazda V6's seem to be a good cheap sources of horses. I understand they're quite compact? Or deez turbo auto? All the torques, and amusing economy. -
Don't forget to have a look at Skope classic, some of us will be out there, (but not me this time, sorry). //oldschool.co.nz/index.php?/topic/38968-christchurch-monthly-meet-next-meet-saturday-7th-february-the-scope-classic-mike-pero-motorsport-park/ http://www.skope.co.nz/about/skope-classic/
Looks good to me. Carry on! (Disclaimer, I only join metal with 60/40 solder)
Rotate the cable receiver 90deg so it's axle/pivot is horizontal, then stuff under and between the trumpets on the left? Your link rod would then run from left to right in your second pic, and push against the springs from the left, rather then pull against from the right. Hmm, though you'd have to rotate the arm on the throttle pivot away from the engine anyways.
Oh, and there was left hook 60's(?) Ovlov wags with a high mileage club sticker, and a hipster with a cool old 3l porka passed through while we were there.
David could you throw a piece of that stuff under a blowtorch or hold in a lighter flame and tell us what happens.. I'll grab a few rolls if you can test its ability to not melt Oh yeah, and film pls
Was cool, Poms do nice beer / pork crackling. Was a laugh watching black smoke racing and power skids.
Internet monies? Dogecoin anyone?
Will be at Pomeroys at the appointed hour, prolly bring the 1100, with new ugly indicator(s).
About 5 years. ish. Dang, some of your photos over on the build thread have fallen off the internet.
Interestingly, got a woffle for my GSXR y'day too. (may need vaguely legit transport while sorting the Dai).
