smokin'joe
Everything posted by smokin'joe
  1. have you tried the local Toyota dealership ? many items are genuinely cheaper than aftermarket.... or importing from outsource suppliers of genuine
  2. yamaha made heads for toyota, so quite relevant !!
  3. Sheldon Rush is the Toyota guru in Oamaru
  4. simply remove ceramic 10A fuse and fit 15A MCB for welding duties
  5. was advised that start-up could be as much as 9X rated power, so may go petrol re-power as long powercords are an arse .
  6. has a query. re-mounting tidying up my concrete mixer, current motor 1/4Hp 1425rpm, non-cap.start....... will not run on 1000w continuous invertor if i replace this motor with 1/2Hp twin cap start....... will the capacitors allow the invertor to run it ?
  7. was there a decent turn out for this event ? went for a quick squizz at the Muster in G-Town, had a decent display for a new event... 200-ish car they reckon, but only the Ford Cortina Club had a decent club dislplay
  8. cock, have to be down this week, but the fella not available for weekend pick-ups. a couple of lads on the list would to catch up with, and few i doubt i have met
  9. coil-over should be located on top of diff and into upper spring perch. the very parts designed to take the vehicle load
  10. TGP were, by far, the cheapest for son's Surf, but ex-Japan. eventhough it is a LN106 with wagon body, BNT/Repco/local brake shop had none in local stock either
  11. ensuring it is not a wheelbearing issue, first
  12. i made a heap of 12vDc heating pads to go under propagation trays, and fitted a basic ' variable resistor' type controller as getting too hot and frying the seedlings. i have a nuggetty 12v coil heater here if you wanted to see if that will work. 12v heating wire wrapped around steel/copper core, incased in concrete inside 100mm PVC. yours if you want it
  13. what about a urethane or PVC jointing cement like plumbers use ?
  14. Clint, is it true, that anything that needs re-vin/re-rego from either June/July this year, needs full chassis/underside strip/sandblast to check for rust ?
  15. but Mr, it is non-turbz 3L choocha mobile
  16. so if the lad fits new sparkbungs to his LN130 manual Surf/4Runner, will is fix the excess smoke and give him more than 15WHP ??
  17. GN's are the current Suzuki farm bike. low seat height works well for smaller built dairy farmers, and knobblies added for grip. we sell them as a new bike
  18. at this rate, i may have replaced the LC80 by 2024 !!
  19. terrible idea, love it !!
  20. but don't you use waste oil as chain-bar lube ?
  21. i didn't realise you had even plotted the route when i first posted about 'key' access. as for setting one up, am not a rider, and with limited L/H function, nor would i endeavour to attempt something of this, as it would need to be ridden prior. i could advise some loops, if wanted/warranted, for a quite compact event. @RUNAMUCK Middlemarch Mainiototo !!
  22. WOW, good coverage, looks like a name change to Midland Madness......... the 'key' comment was to keep it in McKenzie/SCanty, but awesome trails. i do have a more compact 'local to Farlie' route involving keys, if needed
  23. better than mo-ped, which implies moustached pedos !!
  24. i was meaning the route, Baaaart. a couple of keys from landowners will add to the epicness
  25. is it the full 'kit and kaboodle' or the gentlemans scoot ?
