AllTorque
Moderators
Everything posted by AllTorque
  1. KK... consider this your sticker reminder
  2. Get out of bed, fuel up your ride and get to Otaki beach for lunch. It's a cracker day outside kids. See you there.
  3. You could destroy your engine by running too lean. Sounds like you are playing with fire here man, (pun intended)
  4. Most 4 cylinders are 1342
  5. 3. spark firing while valve is still open due to incorrect ignition timing.
  6. It's the Valentines part that makes it so believable.
  7. 1vaknd knows whats up Ignore my posts.
  8. Could it be left hand thread on one side? I'm just guessing now. You did take the split pin out right?
  9. Method for doing up the nut. While rotating the wheel, tighten the adjusting nut until there is a slight bind and all bearing surfaces are in contact. Then back off the adjusting nut 1/6 to 1/4 turn to the nearest locking hole, until the wheel rotates freely with .001˝ to .010˝ end play, or clearance. Lock the nut at this position
  10. OIC. Yep, definitely take the hub nut off. Studs are pressed into the drum.
  11. Dude. You seriously need to stop that fuel leak before you even think about starting the motor. Have you checked ignition timing with a timing light?
  12. To get the rear drums off, undo the hub nut. It probably wont be tight as I suspect it will be taper roller bearings.
  13. hemroids?
  14. Right. Meet at Otaki beach around 12:00. Those who want to convoy from plimmerton weight station be there at 11:00. All details in the first post.
  15. Surely Al would be referred to as BIG BOY
  16. Have you noticed your small child isn't small. You may have to start referring to him as mid sized child.
  17. kk, can you bring stickers and dropper cards for me?
  18. Hands up who is planning to be there saturday
  19. Wellington peeps that want to convoy up meet at the Plimmerton Weigh Station at 11:00. We will meet fourfingapete at pram wendys around 11:30
  20. Try wanganui auto wreckers . 0800 248 748
  21. Great looking car. I like your idea of smoothie wheels. Seedy Al has a couple of mesh visors for sale. Maybe one would fit? See here //oldschool.co.nz/index.php?/topic/38420-fs-external-sun-visors-2-x-mesh-1-x-solid-wgtn/ Come along to a monthly meet some time and put some names to faces. Details here //oldschool.co.nz/index.php?/topic/38404-welly-monthly-meet-wednesday-19th-june/
  22. I'll be there. Meet here. https://maps.google.co.nz/maps?q=otaki+beach&hl=en&ll=-40.737873,175.115998&spn=0.001788,0.004128&sll=-41.039666,175.442452&sspn=1.823001,4.22699&t=h&hnear=Otaki+Beach,+Wellington&z=19&layer=c&cbll=-40.737873,175.115998&panoid=ZcBxBpkzGnnGbHzsixkgkg&cbp=12,289.01,,0,2.75 If any porirua peeps want a ride up give me a holla
  23. Hot wires look good man. plus you cant beat a good shed burnout! You said you were guna use those hot wires on the kingswood. Are they hq (5 x 4 3/4") or commodore (5 x 120mm) pcd? Because they are not the same. Unless they are slotted.
  24. Yeah this would be good. Weather is pretty shit arse for the next couple of months but maybe we could fluke a sunny saturday lunchtime?
  25. Sorry. Boss says no. Edit: ... to both.
