Everything posted by AllTorque
@KKtrips can you pin that stuff in tech articles?
Nice dorts. I hope you’ve found what was rattling around at every corner.
I’m not sure. Probably a percentage. You can get them in different heights.
You could use one of these under the spring https://www.adenstyres.co.nz/products/universal-spring-spacers-10-15mm
Got the door back on, lined up and glass in. (back door is ajar) To get the window out, you need to remove the quarter window first. Installation is reverse of removal. Of course, I forgot this, but got there.
- 96 replies
- 27
- buick
- sportwagon
(and 1 more)
Tagged with:
Hayden's 1985 L200 Tipper- Discussion
AllTorque replied to WhangareiKE70's topic in Project Discussion
Worth the wait. Sweet looking Ute. -
Thinner layer of filler, a few days later this time sand, bog, repeat... Close enough for 10 days before Wagnats and seal her up with epoxy primer It will need a bit more work, but at least it’s good enough to go out of the shed.
- 96 replies
- 26
- buick
- sportwagon
(and 1 more)
Tagged with:
I wasn’t sure if I was going to post this cock up. A bit embarrassing. First time I have used 2 part primer and bog that’s not newtech. Start of January I mixed up too much epoxy primer and slapped it on way too thick. Info sheet said to add filler after 25 minutes. I thought that was a bit soon, so waited a couple of hours before I mixed up too much bog and slapped that on. Checked on it a bit later... FAIL After a week of feeling sorry for myself I ground it off again. and put on a thinner layer of primer.
- 96 replies
- 6
- buick
- sportwagon
(and 1 more)
Tagged with:
I can’t see the pics -
AllTorque replied to KKtrips's topic in Lower North Island Region
I can’t. Too much door sanding to do. see you at Wagnats. -
Fourfingapete's 1963 PB Vauxhall - Discussion
AllTorque replied to fourfingapete's topic in Project Discussion
All good. Feel free to update the build thread. -
@fourfingapete doesn’t come round here much anymore. -
A few of us will be meeting up near hunterville in the first weekend of feb.
@cletus is an expert
Do you have a VIN plate as well or just the chassis number? Here are the WOF rules https://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/general/vehicle-identification/vin-and-chassis-number
Did you find me some?
Shed warming at your place? -
- 96 replies
- 21
- buick
- sportwagon
(and 1 more)
Tagged with:
Then I thought I would see if it still runs. Hasn’t been started since lock down. Connected the battery, primed the carb... Started first turn of the key. Let it run up to temp and gave it a rev for Trev.
- 96 replies
- 16
- buick
- sportwagon
(and 1 more)
Tagged with:
I put the door back on to check the body lines. Hit it with a hammer in a couple of spots but pretty happy with it considering the bog I took out.
- 96 replies
- 5
- buick
- sportwagon
(and 1 more)
Tagged with:
- 96 replies
- buick
- sportwagon
(and 1 more)
Tagged with:
Hopefully this makes @Spencer happy. Guys at Total Bodyshop Supplies were super helpful. This hardener was not cheap, but should keep me going for ages.
@enzee if you have tints you need both wing mirrors
