Everything posted by AllTorque
Do you mean this “replacement springs are self-retaining in their seats at full extension, without the use of non-standard devices such as wire-ties, straps, or external spring locators” I don’t believe those rubber spacers fall into that category. I have used the spacers before and passed wofs with them in.
Those /\ are different. They sit between the top hat and the chassis. The rubber spacers siting on the spring are all good for a wof.
Looks good. Can you still pull the brake lever in all the way?
AllTorque replied to KKtrips's topic in Lower North Island Region
Always keen for 1841 ribs. @Goat @KKtrips @shavenYak@Big Value Buddy @kicker @Steelies@grunta @Shaz @bmxnz11@Nominal Who else? -
No, no certs for light trailers.
Trailer wof rules: https://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/general-trailers No minimum ride height for trailers. There are a few slam trailer builds here. https://oldschool.co.nz/index.php?/topic/28335-kks-slamiler/ https://oldschool.co.nz/index.php?/topic/33131-chriss-scrapping-slamiler/& https://oldschool.co.nz/index.php?/topic/36939-neds-slam-trailer/&tab=comments#comment-1028143
Any old mechanic should be able to sort you out. @Yowzer ?
Yes you can replace the brushes. Get a whole brush holder not just the individual brushes.
Yes, worn brushes. You will only get a few knock starts, so replace soon.
Funny how Al got this with truck mirrors that he removed and now you have put some back on.
At what point are you going to put this in the too hard basket?
You need some sort of proportioning valve or the rears will have to much pressure and lock up.
Your alloys have hubcaps. They reduce drag (actually).
Have you loosened the control arm bolts to relax the bushes at the new ride height? It can help with the pogoness.
I have heard a better flowing muffler helps get the heat out, but it could be an old wives tale.
ford cortina mk1, help, pictures of lower front arms
AllTorque replied to rotor_dude's topic in Tech Talk
@My name is Russell -
“B” is not regenerative braking. It is engine braking. Does not charge the hybrid battery as much in “B” because one of the motor generators are stationary to allow the engine to rotate. All braking and decelerating in “D” will charge the battery.
Great day for it -
@Hot Dog Flavoured Water
https://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/general/exhaust/exhaust-system See point 7 for exhaust noise see epecially how the wof inspector can use their judgment as to if is too loud or not.
Not banned. All four must be snow tyres and have more than 4mm tread. Should be banned tho.
Chain
Why heating? Is it not welded to the flex plate? Should be ok as long as you get it in the same position relative to the starter. Check if there are any tapers in the edge if the teeth that help starter engagement, but usually they would be on the starter, not the ring gear.
But how would the wof man know that the 13B and adjusties are not the parts fitted when the car was certed?
