felixx last won the day on December 26 2012
felixx had the most liked content!
About felixx
- Birthday 02/22/1975
Gender
Male
Local Area
Christchurch
felixx's Achievements
Committed (5/5)
5.3k
!!!!!!Hanmeet 2024 23rd-25th August - Entry Form is up now!!!!
felixx replied to JustHarry's topic in South Island Region
I am in if the 95 surf is allowed -
I will come if I can get a babysitter
I used to have a legacy that sounded like a small machine gun. Poured it in, fixed in 5km However I was rear ended a couple of months later in that car... ... wrote it off so unsure how long it was good for
Going strong, starts on 4th pull ad runs sooo smoothly. Has become my #1 mower
Lawns done twice with this New air filter reduced hunting at lower revs Also it starts on 4th pull now with no WD40 My mower man was out of sparkplugs , but I will get a new one next week!
Good tips there @Dolan
Thanks Pete. I have a catcher but would love an intact mesh for the vents on the top if you have one. Happy to pay
Will try it tomorrow!! Thanks!!!
Why might it need ether or fuel added to carb on starting??
Bloody thing wouldnt start today. Chucked acap of fuel down its neck and it went first pull then did myfront lawn and the other neighbours jungle. We are now a 2 mower family
Goeshard. Air filter is currently 2 pieces of news paper. It goes real well after a carb strip. New fuel lines Maximum power thru ankle deep wet grass. Thanks for the advice
Hmmm ok. Will check throttle lever linkage as when I move it, nothing on the carb linkages moves,
I forgot to print yhe manwell today. Here was the state of the outside of it. So it has throttle and choke butterflies? How do you engage choke??
Thank you so.much
Thinking the pulsing is an air flow issue.. I did notice throttle did not affect the carb butterfly,so will check if the throttle linkage is not broken too. What have I missed? Interestingly the mower needed starting fluid each time, so could I expect a blocked jet..
