Requiemk
About Requiemk
  • Birthday 11/17/1989
    Otago
Requiemk's Achievements
Committed (5/5)
  1. If you get stuck compression tests are nice and easy give you an idea if the engine is healthy and results up around 170-200 might hint its not factory turbo.
  2. Sweet! how does a friday night car cruise sound around the octagon?
  3. http://imageshack.us/photo/my-images/15/20121226150744.jpg/ It looks rather similar? give me a text if its something your after and we can sort something out as im off on holiday up north later this arvo 0276140005
  4. put a pic up of a rx7 s8 wing you are after? i happen to have a factory (possibly s8) wing in my shed. its white too
  5. if you have no luck before the 10th november could stop in on my way through
  6. Yuh still down here in dunedin. Although time doesn't allow i need a new oldschool whipe in my life. As exams come round my lurking on oldschool increases exponentially hahaha
  7. position your plate and ratchet/strong bar apart from each other so you can fit a long pipe/wood/something between and pry in gap in between them to pry ratchet anti clockwise undoing your nut. much easier.
  8. cool build. if the power plant frame is different from manual to auto i have one sitting in the garage collecting dust you could have joe
  9. I have forgot the exact details and pictures cant seem to be found but changing the mounting of the ball joint from underneath to ontop of its chassis location gives you a drop spindle type effect. I did it to 3 of my cedrics all without any issues although it needs to accompany good shocks or uprated springs to reduce all the suspension travel Edit: lower ball joint. memory fading with old age haha. picture shows original location and if mounted on top where the nuts are gives you drop
  10. Has the ball joints been flipped? you gain 2inch drop same travel
  11. fit one way valve to prevent fuel leaking back and use compressed air on fuel tank to push some fuel through.
  12. theres a night stage on tonight at 8.30 im heading to, apparently quite good.
