Jase Posted June 19, 2008 Share Posted June 19, 2008 castlemaine rod shop reckon the standy ecu will run a supercharged set up or with a chipped one will go better, 8.3/1 comp ami gona kill it running 8psi? can you flip an sc14 upside down and run it that way as i want to run it on the drivers side, and is the standy fuel pump going to be enough? Quote Link to comment Share on other sites More sharing options...
Requiemk Posted June 19, 2008 Share Posted June 19, 2008 sc14 = 2litre bit small i thinks. IF you were to say bolt 2 of them on there i dont see whatd be wrong with that Quote Link to comment Share on other sites More sharing options...
Jase Posted June 19, 2008 Author Share Posted June 19, 2008 sc14 is fine thanks plus too expensive to run two at 4 hundred odd each, i want to keep the boost low as well so i can just run the standard ecu, and will also work with the intercooler set up i want to run, not to mention fuel pump etc etc Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted June 19, 2008 Share Posted June 19, 2008 sc14 is 1.4l per rev, m90 is 1.48l per rev. m90 is what thay use on commies. so ful all smaller. Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted June 19, 2008 Share Posted June 19, 2008 is that an sc14? what series motor do you have, aparntly the series 1's dont like boost.... Quote Link to comment Share on other sites More sharing options...
Jase Posted June 19, 2008 Author Share Posted June 19, 2008 looks to be it's a series two so i'm safe, m90 was on the ecotecs and xxxxe Quote Link to comment Share on other sites More sharing options...
Jase Posted June 19, 2008 Author Share Posted June 19, 2008 the motor in that datto is a series one though Quote Link to comment Share on other sites More sharing options...
Jase Posted June 19, 2008 Author Share Posted June 19, 2008 are these sc12s or sc14s Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted June 19, 2008 Share Posted June 19, 2008 the motor in that datto is a series one though yuh and it died not long after that photo was taken Quote Link to comment Share on other sites More sharing options...
Jase Posted June 19, 2008 Author Share Posted June 19, 2008 series twos are a bit hardier the green ones a two you can tell by the return to the radiator, ones from the back twos from front Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted June 19, 2008 Share Posted June 19, 2008 the motor in that datto is a series one though yuh and it died not long after that photo was taken WTF are you guys smoking? That aint no A series. Yes you can run an S/c14 on a commy, but i'd strongly advise you use an intercooler. They can be mounted flat rather than over and under like the factory did it. Thats how mine is mounted. Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted June 19, 2008 Share Posted June 19, 2008 ahahaha, nah bart it is a series one commodore motor. not an A series. Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted June 19, 2008 Share Posted June 19, 2008 I've seen footage of that ute doing skids. It goes nuts. supercharger=FTW Quote Link to comment Share on other sites More sharing options...
Jase Posted June 19, 2008 Author Share Posted June 19, 2008 the motor in that datto is a series one though yuh and it died not long after that photo was taken WTF are you guys smoking? That aint no A series. Yes you can run an S/c14 on a commy, but i'd strongly advise you use an intercooler. They can be mounted flat rather than over and under like the factory did it. Thats how mine is mounted. haha really lol would like to see skid link though Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted June 19, 2008 Share Posted June 19, 2008 cant find a video/didnt look Quote Link to comment Share on other sites More sharing options...
Jase Posted June 19, 2008 Author Share Posted June 19, 2008 as i figure the sc14s are a sealed unit so they must just pool oil in the rear casing so i should be able to run it upside down, then i can still run the set up i want, thats an impressive skid must have the tires goin like 250kmh or has something real heavy in the tray Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted June 19, 2008 Share Posted June 19, 2008 not sure if they like running upside down, I know that they won't like being spun in the opposite direction though. Quote Link to comment Share on other sites More sharing options...
Jase Posted June 19, 2008 Author Share Posted June 19, 2008 yeah i wonder if the green ones had probs as one of those is running upside down, backwards lol won't be doing that aye had an ol te125 that would run bacwards, ie warm it up , up hill to stall then rolling back in gear pop the clutch baap in reverse, insane lil twostrokes Quote Link to comment Share on other sites More sharing options...
