18 minutes ago, HighLUX said:
Can you count input turns to output turns to work out ratio?
Yeah absolutely, though I thought i'd try to find out for idle planning purposes without having to put it on blocks haha. Some barry on one of the narrow gauge pages reckons he has a final drive in pieces and will count the teeth for me, its just a single thread worm drive. Have been looking into 48v forklift motors, pretty cheap secondhand and they look similarly sized to the original motor.
You have to love the internet, how else could you find the reduction ratio of the final drive of an obscure british mining locomotive in 2 hours from the comfort of the couch. Ratio is 31:1. Now I just have to measure wheel diameter and I should be able to figure out necessary RPM for 3.1mph/5kph, which is plenty for what it is. In its original form this would pull 16.5 ton on the flat, down to 3.7 ton on a 1:50 grade. I'm hoping to achieve at least 300kg towed at 1:20 or greater, the line at waikino is very steep..
I there's an old mine cart on a farm I go to occasionally, probably same size. Next time I'm there I'll take some pics. Near Methven, Canterbury.
Probably, 2 foot was a common gauge for small rolling stock. In the day you could buy pre-made track sets and switches to put together like an oversized model train set! There's a few old industrial wagons out at waikino just sitting on "display" that are begging to be restored and run on the tiny mainline
