j.e.d. Posted May 31, 2023 Author Share Posted May 31, 2023 2 minutes ago, dmulally said: Does the digital dash all work? If it works and you like it just terminate it at the fuse box and try and refresh individual wires to the right places. If it doesnt you could always change to a custom analog dash. Would be loads out there to choose from and you'd only ever do it once. The digital dash was prob why it was so hard to find an off the shelf loom. Thankfully being a small block chev you only need three wires or so to run it. Yea I believe it was all up and running.. it’s in km/h as well so I reckon it’s been special ordered from the states.. just surprisingly there’s only 3 or so wires coming out the back 2 Quote Link to comment Share on other sites More sharing options...
j.e.d. Posted May 31, 2023 Author Share Posted May 31, 2023 These instructions for a 91-92 Camaro show more.. might need to have a closer look what’s going on there 1 Quote Link to comment Share on other sites More sharing options...
dmulally Posted May 31, 2023 Share Posted May 31, 2023 Those instructions are pretty good. As long as it didnt throw an error code or you could pull the little globe you could ignore most of C1. Dashes are always fiddly to wire anyway. At least yours has great instructions. 1 Quote Link to comment Share on other sites More sharing options...
Nominal Posted May 31, 2023 Share Posted May 31, 2023 It's an aftermarket dash panel? Would it have been digital originally? 1 Quote Link to comment Share on other sites More sharing options...
dmulally Posted May 31, 2023 Share Posted May 31, 2023 Google suggests this: 1 1 Quote Link to comment Share on other sites More sharing options...
j.e.d. Posted May 31, 2023 Author Share Posted May 31, 2023 yea, the original gauges needs to be taken out of the housing with this digital circuit board mounted at the front. Quote Link to comment Share on other sites More sharing options...
