Kimjon Posted May 20, 2023 Author Posted May 20, 2023 I cut 8 more tabs, brackets off the frame. Then extended some parts of the wiring loom so I could tuck the wires discretely away. Its far from done, but I'm liking the way its starting to look. Hero shots: Then welded up this fender. It had a huge hole hacked into it (not by me). I thought it was destined for the bin...but had a go at welding in a patch. The planishing hammer was awesome for this job. It put a double compound curve into it...no filler will be needed, just some high build primer. this will replace the front fender. I'll weld up some brackets to hold it there. Should look way better than the giant plastic one. 9 Quote
Kimjon Posted May 22, 2023 Author Posted May 22, 2023 Fuck yeah!! Bluetooth mounted for the photos, but will sort my shit out soon. Stoked with these exhausts, so well made. 8 Quote
Kimjon Posted May 23, 2023 Author Posted May 23, 2023 4 hours ago, Lord Gruntfuttock said: How does it sound...? Its just sitting there for now, I need to weld some 38-51mm cone adapters to my headers to properly fit the exhausts. They come with decibel killers that can be bolted in to make them quieter if needed? Time will tell how good the sound reduction is? 1 Quote
Popular Post Kimjon Posted May 30, 2023 Author Popular Post Posted May 30, 2023 This aftermarket airbox replacement cover arrived. Purchased from the UK, not a cheap item, in fact an embarrassing amount to spend on something that adds no performance at all...but fuck yes, looks so good. I'll fit it properly and paint to match the motor. 10 Quote
Kimjon Posted June 3, 2023 Author Posted June 3, 2023 Pretty happy with this. Battery holder/exhaust brackets. 9 Quote
Kimjon Posted June 4, 2023 Author Posted June 4, 2023 Flat out working on this thing. 2 days work, and hopefully no one notices what I've done...should look factory. 8 Quote
Popular Post Kimjon Posted June 5, 2023 Author Popular Post Posted June 5, 2023 Rear sub frame underway. Waiting on mandrel bends to arrive so I can finish it. I've rerouted a heap of wiring, plus HT leads through the engine covers. Next I'll remake the battery cables, and charging system, to reach the relocated battery underneath. really starting to take shape now. 10 Quote
Kimjon Posted June 9, 2023 Author Posted June 9, 2023 Mandrel bends arrived. Time to experiment and see if my thought process checks out...or not...? 1 Quote
Kimjon Posted June 10, 2023 Author Posted June 10, 2023 Yes, I know...pure talent at paint on my phone...but gives you an idea of proportions. 4 Quote
Kimjon Posted June 11, 2023 Author Posted June 11, 2023 New small headlight on order, grips, small 1/2 front fearing (but not 100% committed to this idea). Want to lower bike a touch in the front too. But overall I'm pretty happy with it so far. 1 Quote
Kimjon Posted June 13, 2023 Author Posted June 13, 2023 Smaller headlight. Its not quite where I want it, but it gives me a starting point. Mini fairing on order too, so this is plan B. The fairing could offer nicer way of hiding an ugly instrument display, so might be a winner. Keeping an open mind until I can play with both ideas. 2 Quote
