Head crack repair cast iron. Repairable or am I buggered.
I've got my holden/buick l67 v6 stripped down and I can visibly see some cracking around a few valve seats. Can this be repaired successfully? I have plenty of welding gear and would be prepared to give it a go if it's not too risky.
Also prepared to send out if it's a specialist job if you know someone pipe up as I suspect this is a skill that may be dying out.
These heads are surprisingly thin on ground as cracks on an L67 3.8 v6 is a given later in life not sure on l36 ecotec suspect wont be much better these days as the vast amount of these engines have ended up skid pigs.
There are alloy aftermarket heads but $5k plus for a set is a bit rich.
I would be checking to see if the cracking continues below the valve seat insert which would required getting the head to a reconditioners and getting machined out then following by a crack test.
repairing cracked heads isn't a common thing to do now most end up in the bin and find another non cracked one
On 24/01/2023 at 06:49, vk327 said:
proflow fab in aussie are machining l36 heads to  work as l67 heads now if you get stuck  finding a decent replacement
That's an option. I'm not running the blower so can run ecotec heads but want the option of been able to run a second set of injectors for  E85 on a separate fuel system or even water injectors.
I've looked at 2 sets of heads that we're for sale off an l67 and and l36 both were as chooched as mine so starting get worried about not having a top end for the build.
wouldnt worry about secondary injectors on a 3.8 ,  modern injectors work well at low pulse widths so  not hard to  get an engine to idle with a set of 1000cc or 1350cc  injectors (at this point you'd lose resolution on the stock delco ecu  fuel tables tho) , youd have to be pushing 20 plus psi of boost to  even get close to needing that much fuel  even with e85 and could run 60psi base pressure if needed a bit extra, more viable option would be a water meth kit which  typically  run a single nozzle into the intake, either the fancy  AEM  kit or have done a basic water meth kit before using an AEM nozzle with a solenoid and a tank with an efi pump and regulator on it and a hobbs pressure  switch turns on the solenoid as boost comes on
