GregT Posted December 25, 2023 Posted December 25, 2023 1 hour ago, Lord Gruntfuttock said: Fuck knows. Just what someone would pay really. Just had a xmas lunch conversation with my brother about cafés being worth less than what the donor bike being tidied up would be worth now. Particularly 70s Hondas etc... Very true. Quite possible an original ironhead in tidy nick would be worth more than post cafe work. HD nuts go for originality. And HD are not a traditional base for cafe racers. I get pretty disappointed at the taste shown by some modern cafe builders - particularly when they then try and sell their crap on trademe. This one is well done though. I do like it. 1 Quote
Unclejake Posted December 25, 2023 Posted December 25, 2023 Well, if I lived somewhere with paved streets would buy something like this. I just have little idea if it's $15k or $25k. Moot point anyway I guess. Chur 1 Quote
Lord Gruntfuttock Posted January 25, 2024 Author Posted January 25, 2024 So after falling for a parts scam, I wrote it off to experience and looked at ordering gear from eBay, from a seller I'd used before. Parts are pretty cheap but postage can be a killer. Before xmas I decided to see if removing 3 springs would be a viable interim option. Whipped out the clutch tool, but disappointingly the primary case was again overfull of oil. I'd seated the pump check ball, replaced the engine main seal, fitted a generator oil slinger and installed the starter solenoid rubber boot that was missing, so a bit baffling. Someone here suggested it may be a worn oil pump shaft, I dunno...? I pulled 3 of the 6 springs and buttoned things up again, was quietly confident until this happened... Arse. Completely my own fault, was rushing to get a ride in to test things and instead of using a small spanner I'd wailed on these 1/4" nuts with a socket, just missed the point when it snugged up to the spacer, so bent it and snapped a stud... I looked at machining up a new stud and spacers, but decided to add a new basket and spacers to my spring order, parked the bike, and went camping with the kids over xmas/new years. Was a good break, and I got to wear my new clutch spring/sunglasses... Anyway, parts arrived yesterday... And was nice installing new bits... Quick ride around the section showed a good improvement, clutch seemed to operate cleanly, and less effort required at the lever. Won't know till I give her a good run through town, but encouraging... 3 Quote
GregT Posted January 25, 2024 Posted January 25, 2024 No idea if it's relevant to these engines but the first thing you do on a Ducati single is rebuild the oil pump. Bronze bushes with no seals so wear lets oil piss out and fill the side case. In your case I'd assume it's drain down from the tank ? Quote
Lord Gruntfuttock Posted January 25, 2024 Author Posted January 25, 2024 Yep. Pump under the engine, been on HD forums and you can machine one side of the pump housing and install a seal, but it's an engine out job so it can wait. I think I'll check if it pumps itself out when running by checking oil tank level after sitting first. Quote
GregT Posted January 25, 2024 Posted January 25, 2024 Yeah, that's common sense. If it's drain down, there's always the option of a tap. And a large warning notice. Quote
Nunossauro Posted April 15, 2025 Posted April 15, 2025 On 05/01/2023 at 19:22, Lord Gruntfuttock said: Yeah ta, that pic is deceptive, actually a fine mesh, just been pushed in... And already got a vented bolt on top of the case... I've re-seated the check ball in the pump so that should minimise leaking (sumping), and I expect some to drain in there, that gets pumped back when running - but if I leave it sitting there's several litres that has to be drained out. I'll replace the seal and check that transfer valve and see how we go. Cheers for the advice though, appreciate it... Good afternoon. I hope everything is going well with you. Have you ever replaced the transfer valve? Was it difficult? Did you have to make a special key? Thank you Quote
