Hi all,
My engine is a 4AGZE from an aw11 MR2 1986. I am building the engine up for more power and ultimately want to turbo after getting bored with the supercharger.
I would be very happy with 200kw at flywheel with increase supercharger boost and effective ic.
Other mods are: ARP head studs, port and polish, TRD head gasket, Kelford 193T cams.
I have new Hastings piston rings and need to gap which got me thinking of the following questions.
1. What power can the 4agze low comp 8:1 pistons and rods take? Crank is the 42mm and a 7 rib block.
2. What would be the next week points in the engine?
2. Assuming that is my max power for the build, would anyone be able to guess approximately what boost pressure would get that power?
Thanks
Al
will handle that power fine, long as tune is good.     Doubt you'll make it there supercharged.    turbo, easy with a nice setup.
I've had several 4agze turbo's, 200kw at the wheels will be a piece of cake.
I've had:
4agze big port, 8:1, completely stock internally including cams. Link ECU, t28 turbo.
That made 150kw atw limited by 365cc injectors.
Boost was something like 15psi from memory.
4agze small port
Stock internally. Bluetop cams. 8.9:1. Link ECU and TD05 16G, 510cc injectors.
That made 220kw atw on about 20psi. Super responsive too.
I've had other set ups like a big T04e turbo one and stock 4agze ecu's (AFM and MAP). But those two were the main ones.
The main weakness is draining oil from the head back to the sump. All 16v's suffer from this if racing it with constant high revs. I made baffles, huge external oil drains, completely rebuilt etc etc. They all did it, fwd and rwd etc etc.
I think the best solution is a restrictor in the feed into the head.
Also regarding the supercharger, they are not very good.
They make about 100kw - 110kw at the wheels on a good day. They are just too asthmatic and produce lots of heat.
There is/was a reputable tuner in NZ called Andre Simon I remember talking to him about an S/C aw11 he was working on. I think it made about 115kw at the wheels with lots of playing around. This from the guy who was world famous for his tuning.
Don't get me wrong, the 4agze is a very fun engine. I had a later MAP sensored one (from an ae101) in my old AE86. That had a 11psi pulley, front mount intercooler etc etc, great fun but probably only made 100kw at the wheels, great torquey fun but once I went turbo it was like night and day.
Even a worn out oil burning thrown together stock ecu big port 4agze with a worn out t25g made 125kw at the wheels without even trying (10psi trailing off to something lower because it was stuffed) :smile:
As above, 200kw at the flywheel will be easy with a suitably matched turbo and a good tune.
My old dead stock aw11 ZE made 198kw at the wheels on 16psi with a very old technology T04e turbo and I've seen known many setups making much much more power on stock internals without any issues.
You wont however get the power you want with a stock ecu - they pull heaps of timing from 5500rpm up due to being tuned for the inefficient SC.
8:1 is pretty low comp, so if you want a bit more response then throw a thinner head gasket it at.
depends what your trying to do.  ok if you just want a bit more power.  but turbos have come a long way in the last 20-30 years..  get some newer tech on there,  same spool  more power and/ or easier on engine at same power
  • 1 year later...
I know this is an old thread but I thought I would share some progress I have made - it has been a slow 2 years with ACL surgery, shingles, moving house, fixing Caldina timing belt breakage and major service, kids, wife and life and so on.
pic0(Small).jpg.b90187db67e4849fec4a7f2e5af074d1.jpg pic2(Small).jpg.4e2df87236e6cacb9a889bea9213f5bc.jpg
While the colour looks like a poor service history, the cycling bore were in okay shape and only needed the 2 thou to get a machined finish. No cracks in crank and journals in polishable condition.
Just too off the rough cast flashings 4AGZE head with a good result after decking.
Cleaning up and painting components is time consuming - but hey, this is a labour of love.
pic3(Small).jpg.c1173910508176909768a1caee03f663.jpg pic4(Small).jpg.7b07bda7d7f8041180d3bdbc61134729.jpg
Was awesome to bring the decked block back together with all the painted and machine parts
Old alternator on left had been the cause of a fire that too the car off the road, new alternators are only available in non supercharged versions which means the mountings are clocked differently - but that was fixed with a bit of bracketry.
pic6(Small).jpg.e49c7cfbd8961eb200fcbb0d60cad88c.jpg pic7(Small).jpg.1167ab20a1d95aec61f58cd86d2c3a13.jpg
A long 3 month wait for Excedy to build a sports clutch. E51 gearbox sourced through a half cut purchase and now fitted. Also you cannot see, but I have the modded and fitted 4AGE 20V headers
Motor and gear box close enough to being ready to fit, now working on every thing else.
Fitted (with difficulty) clutch pedal and narrower brake pedal as well as clutch master cylinder and clutch line.
Fuel tank was a rusty mess. I tried the cleaning kits, electrolysis (worked but really slow) and then reverted to the tried method of chucking a bad of nuts and bolt and shaking it about. Once clean, I used the kits lining/coating to get the tank ready to go without future rust issues.
pic10(Small).jpg.b5ed88f8f7c1d00f599e1648064521e1.jpg image.jpeg.cc49c35fb9dc0b278289951c4db87dd1.jpeg
This was by far the biggest rust hole in the body work - previous repair work had resulted in an awful lot of silicon being squirted in but after clean up, rust removal, welding and filling, happy days! I was starting to get tired of the endless rust discovery!
Decided to use the more modern spoiler with the stop light in the middle. That of course comes with the task of repairing the damage from the rusted studs.
Have a spare 4AGZE engine from the half cut and once the car is on the road, then I will start planning for the turbo. I just want to finish and drive the screaming chicken!
