MRT1TRD's Oxford of rust and decay
Nominal
Couldn't find an existing discussion thread so..
Looks like an achievable project - good work on the rusty bits so far.
The M/C looks like it has been sleeved with brass, you might get away with a hone, but probably stainless steel sleeves will be needed as you said.
Hi, a couple of points here. Absolutely nothing wrong with brass re-sleeving , the main reason it's gone out of favour is that the amount of specialist skills (and man hours) required to machine to an interference fit  is far more than what is required to machine to a "slopping good fit" and then glue in a stainless sleeve. Remember neither brass or s/s corrodes.
I'm not sure where the "Brass or copper tend to be too soft and oval out which causes it not to return" comes from - I've never seen any hydraulic cylinder re-sleeved in copper? and in all the years I spent working in the brake remanufacturing industry's heydays I never struck a stuck piston caused by oval wear? Yes brass can wear more than s/s but it responds far better to a good hone than s/s ever will, if I'm working on an elderly ride I'm always pleased when I find a brass re-sleeve.
The same old rules apply. Most brake issues are caused by failing to replace fluid on a regular basis; brake fluid is hygroscopic encouraging corrosion and it also degrades when subjected to high temperatures - there's a good reason why we replace brake fluid after a days racing!
Hope this helps and yes I have a soft spot foe Morries. :thumbright:
Somewhere on the net I found data on the pickup that confirmed that the 1/2ton pickups are 15" wheel and 5x5" stud pattern and larger drum brakes.
The diff looks quite large also
But I can't find the link again. It's a rabbit hole, plenty of information on the saloon and traveler but not the van or ute
