rumrum Posted July 23, 2020 Author Share Posted July 23, 2020 2 hours ago, ThePog said: The feeling when you find the barry who knows exactly what you need when you thought it would be difficult, is friendly and helpful, AND gives you trade.... Better than sex. man so good, i shook the blokes hand and said cheers for making this easy, he looked at me like wtf and was like aggghhh mayte it WAS easy wats the problems 1 2 Quote Link to comment Share on other sites More sharing options...
rumrum Posted July 26, 2020 Author Share Posted July 26, 2020 1 1 Quote Link to comment Share on other sites More sharing options...
rumrum Posted July 26, 2020 Author Share Posted July 26, 2020 leg day..... was blown away with how dirty the inner's were, 1L of kero and a can of brakekleen later.... forks have only taken 120ml each and were weird to do as the spring dosent separate from the chrome inner tube so you have to fill the inner with the spring in it then put the outer on upside down to screw them with the 8mm Allen key, they are like upside down/standard fork hybrid weird italianness 3 1 Quote Link to comment Share on other sites More sharing options...
rumrum Posted July 26, 2020 Author Share Posted July 26, 2020 1 Quote Link to comment Share on other sites More sharing options...
rumrum Posted July 26, 2020 Author Share Posted July 26, 2020 no dust covers shits me! will have to find some boots/gaiters 4 Quote Link to comment Share on other sites More sharing options...
rumrum Posted August 15, 2020 Author Share Posted August 15, 2020 @MopedNZ I always see you hating doing tires on insta, am I doing it right? lol 4 2 1 Quote Link to comment Share on other sites More sharing options...
rumrum Posted September 11, 2020 Author Share Posted September 11, 2020 frame back from the powdercoaters in s nice satin grey, wheels coming next week. if your in Auckland I highly recommend powderworks onehunga! 1 Quote Link to comment Share on other sites More sharing options...
rumrum Posted September 13, 2020 Author Share Posted September 13, 2020 yeah nah yeah offered the motor up to the frame and began wiring, started her up too! ringading ding just waiting on wheels from the powder coated and a floating disc imported from malossi Italy scootling got in for me. pretty happy with it 3 1 Quote Link to comment Share on other sites More sharing options...
M.H. Posted September 13, 2020 Share Posted September 13, 2020 On 12/09/2020 at 09:46, rumrum said: frame back from the powdercoaters in s nice satin grey, wheels coming next week. if your in Auckland I highly recommend powderworks onehunga! What did they charge to do that? Im looking for a new powder coat place 1 Quote Link to comment Share on other sites More sharing options...
rumrum Posted September 13, 2020 Author Share Posted September 13, 2020 Just now, 00quattro00 said: What did they charge to do that? Im looking for a new powder coat place ha don't know, will pay when I get the wheels. we use them for work ross is a real good guy Quote Link to comment Share on other sites More sharing options...
rumrum Posted October 7, 2020 Author Share Posted October 7, 2020 5 1 Quote Link to comment Share on other sites More sharing options...
rumrum Posted October 7, 2020 Author Share Posted October 7, 2020 wheels powder coated and came up nicely, new contis on Quote Link to comment Share on other sites More sharing options...
rumrum Posted October 7, 2020 Author Share Posted October 7, 2020 3 1 Quote Link to comment Share on other sites More sharing options...
rumrum Posted October 8, 2020 Author Share Posted October 8, 2020 took it for a brap up the road, very quick! until the fuel bowl empty... habe to suck on the vaccum line to get it to fill as the new carb dosent have a pick up to suit, will need to get a new petcock then I can start tuning very promising so far though Quote Link to comment Share on other sites More sharing options...
rumrum Posted October 10, 2020 Author Share Posted October 10, 2020 got it idling nicely and had a little go up the road, scoot wouldn't get to full throttle sounded like it was getting to much air like when you pull an air box off a standard scoot, did the old fingers over the carb yo see and nope needs more fuel air... changed the needle position and got about 3/4 throttle. ran around breaking it in for a 20 mins..... then held my fingers over the carb mouth to kill it and now it doesn't want to start.. fark left it over night and still nothing. has spark has fuel seems to have compression when I hold my finger over the sparkplug hole. pulled the head, gasket looks fine as does the piston and rings, pulled the reed valve and it looks like my crank is flooded... put it back together after cranking with no plug or reeds to empty it? still nothing so I'm stuck Quote Link to comment Share on other sites More sharing options...
peteretep Posted October 11, 2020 Share Posted October 11, 2020 do you have a compressor to blow into the crankcase if you think its super flooded? 1 Quote Link to comment Share on other sites More sharing options...
rumrum Posted October 11, 2020 Author Share Posted October 11, 2020 1 hour ago, peteretep said: do you have a compressor to blow into the crankcase if you think its super flooded? nah I don't, will swing over to the neighbours and give it a shot.. the crank case seals are probably shot Quote Link to comment Share on other sites More sharing options...
rumrum Posted October 13, 2020 Author Share Posted October 13, 2020 strangest thing.. I pulled the plug again and kicked it over to test spark, nothing... I had been using another plug to test spark...it turns out my new spark plug died, so banged in the old one and fired straight away 2 1 Quote Link to comment Share on other sites More sharing options...
