Will look cool with some massive rubber on the rear
I think just cut the wheel wells off at the body lines and ad about 5 inches
wanting to keep it a sleeper or want to chop the roof?
@Infinit
I would rather not cut the roof!, I was thinking the same thing about the body line as the cut point!, u think I should keep the original motor but work it? Prity sure all the internals are forged....
Would look sweet running rebel with the wheels sticking out past the guards. Shame it's not the '80s any more. Those white steel rims look sweet too. Got a full set?
Mitsi engine or the flathead?
I would rather not cut the roof!, I was thinking the same thing about the body line as the cut point!, u think I should keep the original motorohanga but work it? Prity sure all the internals are forged....
The flat head 37.5bhp I read it has a forged crank and rods....
Cast iron slugs in there I think, haha. I may be thinking of the flathead super minx
AMR500 supercharger and you will gain 40% power.
Otherwise shave the head a couple mm, port and polish, bigger inlet valves, extractors and 1 big carb. Can skim the flywheel about 10% while you are at it.
21 minutes ago, tortron said:
3 minutes ago, tortron said:
The body isnt going on that l200 chassis?
Angry flatheads sound cool tho. Il race you
No the diff is in the rear and the front will be made to bolt onto the rails. Should be able to get some serious lowness from it to
so does angry L series. I've got a couple spare if you want that option.
No only 2 :(
