LT 250 Quadrunner restore
NVMPAJ
I picked up this Quad , I think it's a 95 , hopefully I can decipher the VIN and work out the year.
cost so far purchase price ...$50 ( yes you read right )
.                   Battery $100 installed and tested
                    Muffler $25 cheapie off "Wish" ( waiting on delivery )
                    Air filter cap $10 ( coming soon)
                    Air filter         $25 ( somewhere in transit)
                     Oil and filter $50 ( installed ) but will need to change again as clutch slip will happen apparently if I use 10w 40 car oil !!
just thought I'd add the extra costs to the list
                  Fuel Pump $16
                   Carb rebuild kit $35
                   Rear axle universal $50
                   CV boots $25 ( didn't use)
                   Donor Quad $250 ........have enough bits to build another .....less plastics and frame
   heres a short video , got it going after a quick repair of the starter motor . Have got a selection of steel to repair the rusty frame , I found a good one on TM , but I refuse to pay nearly $200 freight .
https://www.facebook.com/JimBoyd59/posts/10209691409740304
Edited by NVMPAJ
Update on costs
  • Replies 74
Diesel oil doesn't have friction modifiers in it so is a cheap solution.
http://www.thewarehouse.co.nz/p/caltex-super-diesel-engine-oil-15w-40-4l/R2040015.html#q=diesel+oil&start=1
Went for a ride today , after spending time trying to start the bloody thing . Has spark , but I'm thinking the carb needs work , cos I find that if I pump fuel in with a syringe it'll start , and idle fine . There's a vacuum operated fuel pump that works , but fuel just doesn't seem to get to the spark plug! But hey it's close to be ready for those fishing trips . ( that's the next learning curve)
Decided to take the pump apart , gave a clean , put it back together . Started her up  went for a quick disturb the neighbours ride. Went well . Left it for awhile and started again , the big test is when I'm back in a couple of weeks . Fingers crossed . Hopefully the fuel pump turns up . Got a front CV to fix plus both boots. A little welding and then I'll see what I can do about the mudguards
mean. quite getting into my ultilitarian type atvs at the moment.
currently got an old YTM200E that I like to bat around the place wearing shorts and hiking boots. loves wheelies and hates turning on ashphalt/hard surfaces/at all if you have people on the back. good fun to slide around gravel backroads
cheap fun. owes me $200 haha.
my brother used to have a 300 king quad, about 1996 vintage. gearing was amazing for some road work (95-100kph on teh speedo) but took forever to get there. I always found it unstable too with all the weight at the back and IRS. bro has pics of it rolling down the side of the ruahine ranges with a spiker strapped to the front and a fallow on the back. hmm.
20170424_125857.thumb.jpg.6f1867cbf271c71bd659fc9dca0c4f13.jpgHere's the parts quad before the strip down . It even turned over after years in the paddock rotting away . Have scored CV joints , all plastics , engine (300cc) , Speedo cable , wheels and tyres and various other bits .
Do you have any recommendations for a supplier for quad tires? Too many burnouts means I really need a set for mine so 22x8.00-10 and 25x12.00-10. Im quite surprised how much they cost on Trademe and there doesnt seem to be too many wreckers selling reasonable second hand ones. Cheers
